DSW pro 660 problems with automatic on/off
Slawo
Slawo Posts: 1
Hi,
I'm having problem to activate subwoofer if set for automatic on /off. Doesn't senses audio and not switching on or
switching to standby after 10 min of work
All OK if power switch set to standby position and activated manually by remote control.
Any idea what can be wrong?
Thanks for any tips
Post edited by Slawo on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited September 2013
    Hello Slawo,
    Welcome to Polk's forum. One of the more common causes is that the selector switch on Polk's subwoofers is a three position switch. Usually the middle position is the "auto" on/off selection. Sometimes it can be a little tricky to get the switch in the correct position.
    If this doesn't help check with Polk's CS department at: polkcs@polkaudio.com or telephone to: 1-800-377-7655.
    Regards, Ken
  • Thorton
    Thorton Posts: 1,324
    Slawo,
    Welcome to Club Polk. Ken's suggestion is good. Also, I've found that the sub will only activate at about med-low to med volume in the automatic on mode. Good Luck.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
