need help picking my projector
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2004
    I would use a dedicated mount. Air flow around the projector will be better.
  • scottvamp
    scottvamp Posts: 3,277
    edited January 2004
    Originally posted by goingganzo
    ok i have decided on the sanyo 70 or Studio Experience Cinema 20HD i found a dealer of the 20 at a good price but cant find sanyo dealers to compare priceses i think the sayno will go for about 150 less. also should i suspend a shelf for the projector or get the mount?
    now it is on to selling my tv sooner i sell the tv sooner i get the front projector
    Wondering what you were up to. I custom built a ceiling mount for mine. Did you get to see it in action????? Must have liked it.
    Here is a link to Projector People where i bought mine. I can get you a small referral discount thier maybe. They have a package on the PLV70. Projector, Screen, mount , cable and Progressive DVD player. Check it out: Bottom Right
    Projector People - PLV70
  • goingganzo
    goingganzo Posts: 2,793
    edited January 2004
    i havent seen them yet but i have herd all good revews. i dont need a screen got the materal and wood to buld it and i need a prety long cable so i am going to order some from sigonal cable. i also found a local guy that will delever the unit and do a basic setup for free. but i dont know if it is worth paying more for the hd20 over the sayno?
  • scottvamp
    edited January 2004
    Ya'll be fine with the Sanyo - basically the same unit. Did you get you screen material from the Ebay guy I posted? How Big are you going? Width of frontstage and seating distance?
    Freaking Exciting - you are going to LOVE it!!!!!!!
  • goingganzo
    edited January 2004
    just around 115 i wanted to go bigger but dident have the room with out bulding a new audio cabinet. my seating distance is i think 12feet but i am thinking of movient it back a foot or two. yes i did get my screen meteral from him i have it in the basement waithing to be mounted on to the frain i have allmost cut and ready to asemble.
    here is my front stage speaker screen speaker then audio cabinet the center will be above or below the screne.
  • scottvamp
    edited January 2004
    Front projector HT owners eventually put thier equipment to the side or rear of the HT. Buy a good simple rack (me and sid) and go BIG. ;)
  • goingganzo
    edited January 2004
    i would love to but i wired everything allready and that would be alot of work and money to get new speaker wire my rack is to the side
    it will go speaker next to the switches screne speaker next to the rack then the audio rack.
    the tiled box next to the couch is gone and the dvd rack is changed.
  • goingganzo
    edited January 2004
    here we go this pic will shop you where the screne wll go grom the left channel over by the light switches to the right channel by the cabinet. it will go form the soffit to the top of the tape on the botom of the tv
