What do you guys think about PrimaLuna preamps?
falconcry72
falconcry72 Posts: 3,580
edited September 2013 in 2 Channel Audio
They look like a pretty good value, but I've never heard one.
http://www.primaluna-usa.com/product-main/prologue-premium/pro-prem-pre
Post edited by falconcry72 on
  • Msabot1
    Msabot1 Posts: 2,098
    Very good hybrid pre.
  • erniejade
    erniejade Posts: 6,321
    Looks great! Wish they had a MC option for the phono. Beyond that, I like the cage so you can see the tubes on the looks. @ $2000, there is a lot of competition in the new and used market from BAT on down to Audio Research. It would be a hard call without some kind of in home trial.
    I also like they have 2 sets of outputs. Although I wish some audio preamps had built in crossovers for sub but that is just my personal thing I guess.
    You figure you might want to add in another 200+ if you want to tube roll it since they don't say what brand of tubes are in it.
  • Msabot1
    Good stuff...unfortunately phono pre is considered optional equipment....Tung Sol tubes is what they use.
    tonyb Posts: 33,001
    Never heard it, but as Earnie said, lots of well known great sounding pre's when you enter the 2000 clams category.
  • steveinaz
    steveinaz Posts: 19,538
    I looked real hard at a PrimaLuna pre some years ago, never pulled the trigger--but they review well.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    I really miss my PL mono's but I heard the preamp stuff was not very good so I never went for it. Your best bet is to look into the mystere brand as its the same company but its higher end and better sounding for the preamp. Another option by the same company is the melody valve and they make the real good stuff so thats my 2 cents.
  • Dawgfish
    Dawgfish Posts: 2,554
    Never heard their pres, but I'm huge fan of their amps. I'm listening to my PL Prologue 4 amp as I type this and it sounds fantastic. Of all the amps I've owned, the PL is my favorite. I know this really doesn't help you out with their pres, but my point is they make great sounding, high quality stuff.
  • schwarcw
    schwarcw Posts: 7,341
    My friend owns an integrated and it sounds great with his Harbeth monitors.
    Carl
  • polkfarmboy
    DSkip wrote: »
    It would scare me off quite a bit that people rave about their power amps. Why? Because when it comes to their pre-amps, all you get is chirps it seems. A company that gets such great press on their amps should have the same people looking hard into their preamps as well, yet you don't see much about them at all.
    They save the preamp for their other lines from mystere and melody
  • Dawgfish
    DSkip wrote: »
    While I can't comment on PL pres sound quality, the thing about them to me that has kept me from not trying them is their higher profile. Most pres don't take up as much room height wise and are easier to fit in a rack. Also they seem to go for a pretty penny, which makes me look towards used stuff from Sonic Frontiers, AR, BAT, Conrad Johnson, Anthem, YS Audio, etc. as my first consideration for another pre.
  • falconcry72
    Dawgfish wrote: »
    I like the high profile, I think they are super cool looking.
    Yea my biggest problem is that my VK500 is balanced input only, so I'd have to use an adapter with a SE only pre, which kind of defeats to the point, but I'd be willing to do it for the right pre.
  • polkfarmboy
    The Melodys all have balanced inputs
    nooshinjohn Posts: 25,461
    Not much of a fan of Prima Luna at all. I have heard their stuff on Maggies and Revels, and did not care for the sound at all.
    It could have been a matter of cheap stock tubes, but for the money , I would lean towards Rogue.
  • Dawgfish
    Gotta say it was either tubes or equipment upstream. I own both a PL Prologue 4 and Rogue 88 Magnum. I've played both on the MMGs you sold me and I prefer the PL by a wide, wide margin.
    Dawgfish wrote: »
    How are the old girls doing anyway? I miss them a lot right now.
  • Dawgfish
    They are doing great! I really like the Maggies. I'm thinking of moving them into my bedroom system now I'm back in GA so I can listen to them more. Got to thank you for selling them to me. I've always wanted to try them and I'm really glad I did!
