CA DacMagic Plus
bobsauto49
bobsauto49 Posts: 973
edited September 2013 in For Sale (FS) Classifieds
This thing is about 10 months old,in flawless condition. Box,manual,and pc included. Pics if needed,but as I said,its minty! Lookin for $400/shipped to conus,paypal is fine,as a gift. This is a very neutral,punchy,acurate Dac,with the best bass I've heard from a dac! It accepts rca,and balanced inputs. It took a lot of money to upgrade imho,to a substantialy better dac. Good Day Gents!
"Everything I ever did in my life worthwhile I caught hell for"
Post edited by bobsauto49 on
  • bobsauto49
    Bump
  • bobsauto49
    Bump for $370/shipped!
    EndersShadow Posts: 17,687
    Folks, this is a GREAT piece of gear. I recently got to hear the standard DAC Magic with my Sunfire and it BLEW me away how good it sounded. I cant imagine how good the newer version sounds.
  • bobsauto49
    Thanx Enders! I wasn't joking when I said I had to spend a couple thousand for a substantial upgrade!
    For those too lazy to google, here are some links for the unit
    Manufacture website: http://www.cambridgeaudio.com/products/dacmagic-plus-digital-to-analogue-converter
    Specifications
    Digital to Analogue Converters: Dual Wolfson WM8740 24bit DACs
    Digital filter: Analog Devices ADSP21261 DSP
    upsampling to 24-bit/384kHz
    Analogue filter: 2-Pole Dual Differential Bessel Double Virtual Earth Balanced
    Frequency Response: 20Hz to 20kHz (±0.1dB)*
    THD @ 1Khz 0dBFs: <0.001% 24-bit
    THD @ 1kHz -10dBFs: <0.001%
    THD @ 20kHz 0dBFs: <0.002%
    Signal to Noise Ratio: -112dBr
    Total correlated jitter: <130pS
    Crosstalk @ 1kHz: < -130dB
    Crosstalk @ 20kHz: < -112dB
    Output Impedance: <50ohms
    Max. output level (unbalanced) 2.1V rms
    Max. output level (balanced) 4.2V rms (2.1V per phase)
    Digital input word widths supported: 16-24bit
    Digital input sampling frequencies supported: 32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz**, 192kHz
    Audio output up-sampling: Fixed 24-bit/384kHz
    Max power consumption 12W
    Dimensions (H x W x D): 52 x 215 x 191mm
    (2.0 x 8.6 x 7.6”)
    Weight: 1.2kg/2.6lbs
    * Steep filter disabled
    ** Digital 1 & 2 Inputs only
    Headphone output
    THD: at 1kHz 0dBFS 24 bit signal with 22kHz low pass filter = 0.001%
    at 20khz 0dBFS 24 bit signal with 80kHz low pass filter = 0.003%
    S/N: -111dBrA
    Frequency Response: 10Hz - 100kHz
    Recommend headphones with impedance between 32 Ohm to 600 Ohm.
  • bobsauto49
    Ur da bomb Enders!
  • nhhiep
    nhhiep Posts: 877
    currently I've MF V-DAC II and thinking about trying this one. has anyone tried both? how are they compared?
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    I compared the earlier version of this with the MF DAC, and they're actually fairly similar sounding. They both have a fairly laid back sound to them. If you have the MF and are looking something a little more exciting then the DACMagic isn't really your best bet, but if you're wanting something with a similar sound but with all the extra features and a headphone amp then this definitely looks like a great option.
  • nwohlford
    nwohlford Posts: 700
  • nhhiep
    nhhiep Posts: 877
    the only feature that I like is the pre-amp. this way I can plug it directly to the amp. another item for about the same price is
    Grant Fidelity TubeDAC-11. any thoughts on that one?
  • bobsauto49
    This is sold! Ty Enders!
