How many of you guys use two Pre Pros?
Sumerian
Sumerian Posts: 490
edited August 2013 in Electronics
Just curious on how many of you guys have 2 pre pros (one specifically dedicated/good for stereo and one good at HT ) connected to a Amplifier?
So that you can have best of both worlds? this is how it is done?
If that is the case i am curious how the connections between the systems will be ?
Post edited by Sumerian on
    txcoastal1 Posts: 13,519
    edited August 2013
    There are several 2chnl preamps that have an HT bypass feature which requires an additional set of IC.
    Here is a thread with the options
    http://www.polkaudio.com/forums/showthread.php?81193-Help-explain-what-HT-Bypass-is-for-2-channel-preamps
  • Sumerian
    Sumerian Posts: 490
    edited August 2013
    txcoastal1 wrote: »
    Thaks for the references, appreciate the help.
  • Msabot1
    Msabot1 Posts: 2,098
    edited August 2013
    I use two dedicated systems....one for video...one for audio.
    heiney9 Posts: 25,534
    edited August 2013
    I don't have an HT system per se, but I use two pre-amps for my singular 2 channel rig (I also watch movies on the 2 channel). One tubed and one SS. The SS pre-amp has an HT bypass and I run the tubes pre through that. My SS pre can be passive or active so in essence I have 3 choices on the same rig; tubes, SS active, SS passive. It works extremely well with no sound detriments.
  • Sumerian
    Sumerian Posts: 490
    edited August 2013
    Msabot1 wrote: »
    Could you please let me know the systems you are using?
    Thanks in advance.
  • falconcry72
    falconcry72 Posts: 3,580
    edited August 2013
    Yea, the best way to get the "best of both worlds" is just to have (2) separate systems. See my sig.
    But yes, many people use a 2-channel preamp with HT bypass in their HT rigs, and I think that would be a very nice alternative.
    My suggestion to you is to wait until you get all the other gear you're amassing right now, and then just listen for a while. I mean "a while" as in weeks. Play with speaker placement, AVR settings, etc, and just see what you think.
    The whole point of adding or swapping out equipment is to alter the sound to your liking. You won't know what you want to alter about the sound until you listen! Once you listen, you may be perfectly satisfied... if not, you'll need to determine a very specific attribute of the sound that you want to change. You will then decide what gear to add or swap based on the specific way that you want to change the sound.
    Hope this helps.
  • Msabot1
    edited August 2013
    Sumerian...don't usually get on here to talk about what I'm running other than LP's,but if ya wanna know..here is my somewhat modest setup....THEATER....Onkyo TX-NR-1010....LSim 707 fronts..CSi A4 center...Eosone RSF 600 rears. Audio..McIntosh MC 240 amp...Mx110 pre...for backup....Onkyo Integra P304 pre M504 amp...Music Hall MMF 5.1 table...Harmon Kardon FL 8380 CD..The Mac equipment is vintage gear my dad gave me. Also REVOX R-R. I switch out components from time to time,but leave the speaker setup pretty much intact...
    EndersShadow Posts: 17,723
    edited August 2013
    I have 3 different systems (HT, 2 channel in office @ home, headphone at work). I have pre-amps for all 3 system.
    With that said I have heard NOTHING but good things about Pioneer Elites MCACC and I know lots of folks using that AVR as their pre-amp for HT or even using the AVR itself without a dedicated amp. This way you can enjoy both HT and 2 channel through one system.
    So if you can afford one of the Pioneer Elite SC models you might be able to get the best of both worlds, and then later on add a dedicated amp if you think you need it.
  • dracoskeeper
    dracoskeeper Posts: 142
    edited August 2013
    I run a Onk PR-SC 886 for theater and rotate out both tube and ss preamps. When I listen to 2-channel I just switch input cables into my main amp. Its a "hybrid" system with the best compromising, IMHO. Although, I just recently had to rebuild my Onk's hdmi board, while it was on the bench I watched Avatar with my tube pre. My dogs were freaking out during the jungle scenes,it was apparent they were hearing things they had never heard in surround! At one point I had to pull my male away from my left speaker fearing he was going to attack it! It brought me back to the days before Dolby/Thx... A high resolution 2-channel set up is still very impressive for movies.
