Hsu vtf-2 mk4 vs svs sb12-nsd
Hi all
So I have been looking for a a while for a Sub for My stereo rig. I have come down to the two mentioned in the title. This will be paired with Polk LS-70 and sometimes ADS L690 for music only. The room is about 14X14 and I will be upgrading from a basic cheapo Sony 8" sub-woofer. I was looking for a use one, but for the price of this two units is better to go new.
I will probably also do some testing in my HT setup just for fun and hope that it does not stay there and I end up moving the JBL to the room for music.
I plan to order in a few days. Any comments welcome....
Cheers
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
Post edited by Irrenhaus on
I have the older PB10-NSD from SVS - love it.....not that really helps you any. Never heard any of the Hsu's.
I have a SVS PB13 and have owned a HSU VF3 MK3. I have not heard the SVS sub you mentioned but I doubt you could go wrong with either sub.Speakers: SDA-1C (most all the goodies)
The title is a mouthful...
As others have mentioned, you cannot go wrong with either.
SVS weights 35lbs while HSU weights almost twice as much at 64lbsAMP/Pre Pro: Outlaw 7000x, Marantz AV7703
Speakers: Fronts:LSiM 705s/ Center: LSiM 706c / Surrounds: LSim 703s
SUB: Rythmik LV12R x2
Source:OPPO UDP-203 -
If you are leaning more towards a musical sub, I would suggest the SVS, and if HT is more important the HSU.
