Center advice needed
ForceV4
ForceV4 Posts: 14
edited September 2013 in Speakers
I have a chance to pick up a CS1000P. I've lusted after one for years even though I've never even heard one or even seen one in person-it just seems neat. Currently I have a CS400i and it seems to do the trick quite nicely. The mains are RTi12.
Questions.
1. If a center such as the 1000 is as amazing as some claim, why doesn't anyone make such a thing?
2. Will the 1000p match the RTi12 nicely?
3. Is this speaker supported by Polk anymore?
What are the pros/cons to this change aside from the 1000p being an absolute monster (that doesn't bother me in the least)? Is it so much better than the 400i that I shouldn't even be asking questions?
Thanks so much.
Have a wheelie nice day!
Yamaha RX-V3300
Yamaha CDC-585
Yamaha DV-C6480
RTi12 mains
CS400i center
RTi38 r/l surrounds
OWM3 presense
PSW 202
RTi100 B channel powered bedroom speakers
Post edited by ForceV4 on
  • falconcry72
    falconcry72 Posts: 3,580
    edited August 2013
    - What do you mean?
    - It's not a perfect match. The CSi and CSiA series centers are perfect matches.
    - maybe, but you should call Polk CS to confirm.
    - pro is better bass.
    - con for both the 1000p and the 400i is that they are not matches to your RTi12's.
    I would go for a matching center. The best center channels for you are the CSi5 and CSiA6. The CSiA6 is just a cosmetically updated current version of the CSi5, but both are perfect matches and both are excellent center channel speakers.
  • nhhiep
    nhhiep Posts: 877
    edited August 2013
    i've the rti12s as well and very happy with the csi5. it's around $225 on ebay now, very fair price. A6 is way expensive at anywhere near retail price. anything else will sound weird.
  • rooftop59
    rooftop59 Posts: 8,121
    edited August 2013
    Well if he's happy with the 400i, then he will be happy with the timbre of the 1000p. I would say biggest con is that that generation of amps are known to go bad. I am running a cs400i with a little mirage 8 in sub crossed over at about 60hz, and it sounds great. I can't imagine the 1000p being any better, and its a more cheaper option that's easier to fix if the amp goes bad since the sub was very inexpenseive to begin with.
    If the price is right it might be worth a shot, but I wouldn't want to risk that amp giving out...
    Game Room 5.1.4:
    Bedroom 2.1
  • ForceV4
    ForceV4 Posts: 14
    edited August 2013
    Thanks all for the feedback. I think I may stick with the 400i since I already own it and like it. If I trip over some funds perhaps I'll pick up the CSi5.
    I'm still intrigued by the 1000p and would love to have one to listen to back to back with my current set up. I'd have no problem coughing up money if it were truly better.
    Why doesn't anyone make such a center channel? It seems to me that with so much sound coming from the center that the 1000p ought to be just right. I've never seen anything else like it (powered) or with so many drivers. Maybe that is why I'm fascinated.
    Yamaha RX-V3300
    Yamaha CDC-585
    Yamaha DV-C6480
    RTi12 mains
    CS400i center
    RTi38 r/l surrounds
    OWM3 presense
    PSW 202
  • falconcry72
    edited August 2013
    ForceV4 wrote: »
    ...Why doesn't anyone make such a center channel? It seems to me that with so much sound coming from the center that the 1000p ought to be just right. I've never seen anything else like it (powered) or with so many drivers. Maybe that is why I'm fascinated.
    What do you mean by "such a center a channel"? If you mean a center with powered subs, the reason that most centers don't have powered subs is the same reason that most speakers in general don't have powered subs: you can't get great bass that way. Great bass comes from big dedicated subwoofers, not from hybrid/powered center channels or towers.
    As far as the quantity of drivers, quantity does not equal quality. There are tons of huge center channels out there, some with lots of drivers and some with just a few.
    A center channel is no different than a tower speaker. When I think about the best tower speakers I've heard, none of them have built-in powered subs, and some of them are simple 2-way designs with just (1) tweeter and (1) woofer.
    Get that CSi5 and see what you think. If you find a good deal on a used one, you could just flip it if you don't like it, but I think you will.
  • ForceV4
    ForceV4 Posts: 14
    edited August 2013
    Falconcry72, how dare you introduce common sense, logic and sound reasoning! :lol:
    You guys/gals are right. No CS1000P for me. I'll see about the CSi5 shortly. Thanks for the feedback and help.
    Yamaha RX-V3300
    Yamaha CDC-585
    Yamaha DV-C6480
    RTi12 mains
    CS400i center
    RTi38 r/l surrounds
    OWM3 presense
    PSW 202
  • RamZet
    RamZet Posts: 792
    edited August 2013
    Drivers!
    Look at the Paradigm webpage and click in center.
    no built in powered sub.
    B&W CM9Classé Sigma
  • gumbay13
    gumbay13 Posts: 360
    ForceV4 wrote: »
    If you do have a Frys in your neck of the woods, they do have the CSi5 on sale for $99.00!
    AMP/Pre Pro: Outlaw 7000x, Marantz AV7703
    Speakers: Fronts:LSiM 705s/ Center: LSiM 706c / Surrounds: LSim 703s
    SUB: Rythmik LV12R x2
    Source:OPPO UDP-203
  • evertune
    evertune Posts: 8
