Audio-GD new products
zingo
zingo Posts: 11,258
edited February 2014 in Electronics
I check out the Audio-GD website once a month to see what they are doing, and it's been a lot of headphone amps and DACs lately; which is their bread and butter. However, they recently released an integrated amp with dedicated headphone section, and a new power amp that's designed to be more musical and less analytical than their Master series. Having owned a few pieces of their equipment, I would highly recommend their over-built equipment if you were considering budget brands of electronics.
Precision 1 Integrated amp: 90W @ 8ohm, 170W @ 4ohm for $550 including remote
SA300 MK3 amp: 250W @ 8ohm, 500W @ 4ohm for $1330
Post edited by zingo on
  • zingo
    zingo Posts: 11,258
    edited August 2013
    I chatted briefly with Kingwa about the SA300 MK3, and he designed it with ques from the classic Accuphase A100; high bias, no opamps or coupling caps. Even though the input stage is claimed to be pure class A, clearly the output stage is class A/B, but a high current design with a 750w transformer for each channel and doubling power between 8 and 4 ohms. :eek: Kingwa also said the different between this amp and his Master 3 power amp which has similar specs, is increased harmonics for a larger and more musical presentation. I'd be happy to judge those comments for myself if anyone wants to sponsor me... :mrgreen:
  • falconcry72
    falconcry72 Posts: 3,580
    edited August 2013
    That SA300 MK3 does look really cool.
    Jake, you got me into Audio GD a few years back with that NFB-7. Still haven't found a better sounding DAC, but I'd love to pickup a Master 7 if one ever popped up used.
    VR3 Posts: 29,627
    edited August 2013
    Am I overlooking the preouts or it definitely does not have preouts?
  • zingo
    zingo Posts: 11,258
    edited August 2013
    Does not appear to have preouts, and input one is their ACSS connector which uses current gain instead of voltage gain.
  • zingo
    zingo Posts: 11,258
    Audio-gd just released the double of their Precision 1 integrated amp listed above: http://audio-gd.com/Pro/amp/Precision2/Precision2EN.htm
