re-clothing rta12c Hats
soundfreak1
Anyone done this or had it done?? Not something i can even consider doing myself.my local shops wont touch them! Need ideas or advice ! Thanks in advance.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Post edited by soundfreak1 on
I would think you would need to have the corners sewn together by someone with experience...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Try a upholstery shop I would think they could do them.
Dan -
Upholstery shop thats a good idea. Dose any know how the cloth is "pined in the groove underneth , it loods like some kind of "spline" like on screen on a screen door?????Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
soundfreak1 wrote: »Upholstery shop thats a good idea. Dose any know how the cloth is "pined in the groove underneth , it loods like some kind of "spline" like on screen on a screen door?????
Yep, I think that's what it is. Let us know how it turns out."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
A friend of mine had some & had the same problem. That happens over time with those hats. You may find some shops may not tackle the job. But im sure there are some that would in your area. If you were up here in Maine there is Hill's Upholstery that will do grills & more. Old timers that do great work are out there. GL with you projectRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
