Surround timber matches for RTiA5 towers
Jestered
Jestered Posts: 49
edited August 2013 in Speakers
Hi all,
I'm waiting for my new RTiA5 towers to be delivered and was looking for some surround timber matched speakers to use with them. I also have the CSiA6 center speaker coming with the towers, so my front stage should be set, although I plan on adding some front high speakers at some point. So, I have some Polk RT15i bookshelf speakers that I haven't used in a while and was wondering if I could use these as my surround speakers with my new tower and center channel that's coming. I know the towers and center channel are matched, but are the RT15i speakers timber matched with those? I'm assuming they are since I believe those RT15i speakers are (used to be) part of the RTi model range. Can anyone confirm?
My plan is to add the FXiAx speakers as my surrounds (eventually) and use the RT15i speakers for front high speakers. I just want to make sure the RT15i speakers are a match or not.
Thanks in advance for any input you can give!
Samsung 65" ES8000 LED
Pioneer Elite VSX-53
Polk RTiA5's - Front Towers
Polk CSiA6 - Center Channel
Polk RT15i's - Side Surrounds
Polk FXiA4's - Rear Surrounds
SVS PB-1000 - Subwoofer
URC MX5000 - Remote
Post edited by Jestered on
  • Geoff4rfc
    Geoff4rfc Posts: 2,805
    edited August 2013
    Congrats on your A5's. Your 15i's should make great surrounds until you pick up your FX's
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • Jestered
    Jestered Posts: 49
    edited August 2013
    Geoff4rfc wrote: »
    Thanks! I'm excited to get them. I'm hoping they get here this week, but I'm guessing it won't be until next week. I'm also glad to hear the 15i's I already have will suffice until I can get the FX's later.
    Thanks again!
    URC MX5000 - Remote
  • specd_out
    specd_out Posts: 505
    edited August 2013
    surround speakers being timber matched arent nearly as important as the front sound stage. I wouldnt spend much on surrounds unless your going to get the fxi series.
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
