Help-Best budget Pre Amp for Power AMP for LSI M705's Pair
Narikisas
Narikisas Posts: 9
edited December 2013 in The Clubhouse
Hey Guys-
I am starter in Audio world
Looking for a Budget A/V Pre Amp and Power APM for LSiM705, Should I go with emotiva UPA-700 , UMC 200 Any Better Suggestions ?- for Bi-amping should i buy 2 of UPA-700 ?. Trying to set up a 7.1.
Thanks in Advance.
Post edited by Narikisas on
  • B Run
    B Run Posts: 1,888
    edited August 2013
    Welcome to the forum! What is your budget? Do you have the other speakers already? Do you want new or can it be used? Emotiva is a touchy subject around here, i'm sure plenty of people will chime in and give you some opinions.
    F1nut Posts: 52,002
    edited August 2013
    Look around for the Marantz AV7005 pre pro and MM7055 amp.
    Forget bi-amping.
  • Narikisas
    Narikisas Posts: 9
    edited August 2013
    Thank you!
    Budget $1200 for both New Pre -Amp and Power Amp. I have a Jamo Jamo S 506 HCS 3 Home Theater System Hooked to Panasonic BTX-70 Home theatre.
  • dawaldo
    dawaldo Posts: 3
    Want to buy an Adcom GFA-555 for $350, that leaves you $850 for a high end used pre-amp?
  • maximillian
    maximillian Posts: 2,149
    Depends on the power level required, but I would vote for a used amp. I have not heard the LSiM's, but I like the neutral sound that an Adcom produces with the older LSi series. I've got an Adcom 6000 5 channel LSi setup and it works real well. I don't crank the system, but it plays plenty loud for me.
