? about burnt cd andi-pod replay
leftwinger57
As some of you know I had a little problem w/ my I-Pod playing the same 35 songs or so and couldn't ditch that in anyway.I went to the Apple Store and they did a master dump of my tunes and they showed me how to reload my entire library holding so far at 499 songs.That's done and not repeating,but on a few songs of burned CDs that I get the originals from my library they seem to skip like a bad LP.Now I went back to the disc itself played them and not a skip on it through a cdp.So were's the problem and 1 solution I know is to get the original CDs and import it again.
It sounds like you are having issues importing your CDs into iTunes. Sometimes a CD-R will play fine in a CD player but in a CD/DVD drive on your PC, it may not read correctly. The best thing to do if you encounter the issue you are having with your ripped files skipping is to change the import settings for a CD in iTunes. Navigate to Edit > Preferences in iTunes. On the General tab, select the Import Settings button for a CD. On this window you can change the compression type and the bitrate you want to use. The important note however in your case is to check the box for Use error correction for Audio CDs. This will ensure that the files you read are accurate and the CD/DVD reader is not missing any information from the CD. It will make things slower on ripping your discs, but you should get better results.Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Yamaha RX-V3800 Receiver
Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable -
Thank you very much if I can navagate this it will not happen again .I have already deleted the beadt CDs from my I-tunes Library and are also off the I-pod it'self.I knew someone out knew the f I was talking about.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
