Bi-amping question
rmaiers
Is it possible to split the preamplifier outputs to drive to separate power amplifiers?
I am using a Nikko NR-1019 as a preamplifier for an Adcom GF-1 amplifier. I was thinking of splitting the signal and using the Nikko amplifier to drive a subwoofer.
Yes you can.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Yes. Is that a problem?
What you seem to be looking to do is drive a subwoofer where there is no sub output available. You can't just split the Nikko preout signal then combine the two channels at the end of one "Y" adapter to drive the sub. That will create all kinds of loading and channel summing problems with just Y adapters alone feeding the Adcom and subwoofer inputs.
I strongly suggest a device like the Rolls SX45 active crossover ($76 at Parts Express), which has a dedicated sub output that will drive your subwoofer. You can use Y adapters to feed the Adcom and Rolls inputs. Plug the subwoofer into the Rolls unit sub out. The Rolls unit will present a high enough input impedance to the Nikko preouts so as not to cause loading problems and summing of the signal seen by the Adcom.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=245-1184
Party System: Laptop #2 | Audioquest Dragonfly USB DAC | Technics SU-A6 | Acurus A-250 | Radio Shack 15-band EQ | Pioneer SR-9 reverb | Cerwin Vega DX9's | Dayton 100° x 60° horns with titanium HF/MF compression drivers. -
Thanks Glen B! I tried just splitting the preout with a Y RCA splitter and it didn't work. Luckily it didn't seem to hurt anything.
The following wiring configuration should work. I have an Adcom GFA-1 too BTW I'm currently using it in my party system, to drive tweeter/midrange cabs. It is a great sounding amp and fantastic bargain that is at home in any system.
Parts Express was sold out but I got one for $72.00 free shipping. Thanks again for the good advice!
