SDA interconnect
drumiv
drumiv Posts: 171
edited August 2013 in Vintage Speakers
Is the interconnect anything special, as far as how it's made, or what it's made of? I noticed it is one of the upgrades for the SRS's. I can have one made locally if I know what the specs are/should be.
Post edited by drumiv on
  • Phasewolf
    Phasewolf Posts: 514
    edited August 2013
    Do you have the blade blade or is it a pin blade type connector on your setup?
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
  • Schurkey
    Schurkey Posts: 2,104
    edited August 2013
    drumiv wrote: »
    Nope. Just ordinary OEM cabling, with unusual ends. Like any other speaker cable, LCR + noise will be important, Voodoo and manufacturer's propaganda will have no effect on the sound quality.
    I'm thinking the original cable is 16- or 18-gauge; and for most applications it's excessively long. General rule: the blade/blade style uses two individual conductors, the pin/blade has two conductors, but I think the second one (blade) is unused.
  • boston1450
    boston1450 Posts: 7,671
    edited August 2013
    Attachment not found.I would say YES it makes a difference in quality of cord.would lesser work-probaby. As you can see from this pic. I have one stock one & one jerryrigged one. I also need a better quality one to replace my stock one-in due time :)
    F1nut Posts: 50,748
    edited August 2013
    drumiv wrote: »
    Your SDA SRS speakers use the blade/blade type connectors. The original cable was 16 gauge with one wire connected to the large blade, the other to the small. Polk sells a replacement for about $40.00. Many of us have upgraded both the cable and connections. Some use binding posts on the speaker with bananas or spades on the cable. Others use SpeakOn connectors, which I highly recommend. Like speaker cable, the choice for the SDA cable makes a difference, so choose wisely.
  • oldmodman
    oldmodman Posts: 740
    edited August 2013
    Since this thread is about interconnects for the SDA system I do have a question.
    One of the speaker pairs I have came with a plain cable with the pin blade connection on the end.
    The other is the same but it has what appears to be a transformer in the middle of the cable. What is it's purpose and which one would be the best to run?
    Is this the Polk inexpensive version of a Dreadnaught?
  • zingo
    zingo Posts: 11,258
    edited August 2013
    Yes, that is the factory isolation transformer IC and is a more rare item.
  • drumiv
    drumiv Posts: 171
    edited August 2013
    Mine is the blade-blade. So it's basically speaker wire, is that right? I'm a firm believer in bigger is better, as far as cable goes, so if I use 12 ga. wire with the SDA blade-blade connectors, I should be go to go?
    pitdogg2 Posts: 25,683
    edited August 2013
    drumiv wrote: »
    yes you should be good to go...just don't use cheap home depot wire or anything like it.
  • zingo
    zingo Posts: 11,258
    edited August 2013
    A larger gauge SDA cable is not a bad idea, but you will either have to change the connector type, or find/buy new blade-blade terminations.
    F1nut Posts: 50,748
    edited August 2013
    drumiv wrote: »
    Or you step up your game...... http://www.polkaudio.com/forums/showthread.php?142058-A-slightly-different-take-on-the-Dreadnought&highlight=slightly
  • oldrocker
    oldrocker Posts: 2,590
    edited August 2013
    I did not know Polk sold an interconnect cable replacement. Thank You!! I need one.
    F1nut Posts: 50,748
    edited August 2013
    They sell the blade/blade version only.
