Monitor 10B tweeters
rmaiers
rmaiers Posts: 145
edited August 2013 in Vintage Speakers
I have a spare set of peerless tweeters and I'm wondering if I can do a straight swap with the existing tweeters (I think they are the silver face SL2000) or would it require a mod to the crossover?
Post edited by rmaiers on
  • geppy1
    geppy1 Posts: 3,075
    edited August 2013
    Not a good idea for a few reasons The hole in your late 10Bs is taller then the hole for a peerless whould be. You could work around that but the drivers and Xovers are different. Best off to call polk and order RDO194s. Plug and play and they are smoother. keith
    Late 10Bs 1985-87 use MW 6503s. and SL2000
    Early 10Bs late 1983-85 use 6600s or 6501s and the SL1000
    10As 1981-83 use 6500s and peerless (several different versions )
    10s 1978-80 use 6500s (gray edeges and the Denmark made peerless
    Same Xover used 1978-85 with 10s,10As and early 10Bs
  • StantonZ
    StantonZ Posts: 445
    edited August 2013
    You already got the answer (no) but I faced the same decision and chose to go the RDO-194 route AND rebuilt my XO's. I have a pair of 4's w/peerless tweets that I wanted to "match", but it turns out that swapping the SL2000's for the 194's was better all around (they match well enough).
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • rmaiers
    rmaiers Posts: 145
    edited August 2013
    Thanks for the responses. I guess I'll hold on to the peerless tweeters as spares for my RTA-12Bs.
  • rmaiers
    rmaiers Posts: 145
    edited August 2013
    Geppy,
    Thanks for the info on the tweeters. I remember you as a real RTA 12 expert. I have a set of RTA-12B cabinets I'm getting ready to toss out but if you would like them you're welcome to them. Or anyone else who could use them. I was going to make a LF-14 subwoofer out of one but picked up a LF-14 with the Monitor 10Bs I got.
  • dfl733
    dfl733 Posts: 1
    edited August 2013
    Somebody have a pic of the 194 tweeter?
  • Faustin
    Faustin Posts: 1,149
    edited August 2013
    Here is a picture of a 194 tweeter mounted on the bracket for a RTA 12C.
