PSW650 Won't Turn On!
Sandro
Sandro Posts: 2
edited January 2004 in Troubleshooting
So after waiting a month to get my HT receiver I was finally ready to hook up my brand new RM7600 speakers which comes with a PSW650 sub. After MANY hours of drilling holes in walls and running speaker wires I was finally ready to fire up my system and see what it could do. Much to my disappointment I couldn't get any life out of the sub. No green pilot light and no sound. Could this be anything other than a defective sub?
Post edited by Sandro on
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited January 2004
    Is the sub plugged into a live outlet? Is the sub power switch turned on? Do you have a sub cable running from the AVR to the sub and in the AVR do you have the sub set to yes/on?
    SVS
  • Sandro
    Sandro Posts: 2
    edited January 2004
    The fuse blows as soon as I plug the unit into the wall!!!
    I already replaced three of them just to be sure. I tried it with and without the receiver plugged in. I don't even have to turn it the power switch on. At this point I have to say I am not happy with the quality of POLK subs. The only way I see this getting out of the factory is without testing which is always an indication of poor quality.
  • Dr. Spec
    edited January 2004
    Bad amp or bad outlet. Try another outlet to be sure. If the fuse blows again, it's probably a bad amp, or maybe power cord. Email Ken S at Polk Tech Support and he will fix you up straight away.
    SVS
