Monitor 4A Tweeters
sjt_711
sjt_711 Posts: 3
edited August 2013 in Vintage Speakers
Hi all,
I came across a great deal on a set of Monitor 4A's. The tweets are bad in them. Does anyone out there have a set of these they would be willing to part with? A friend suggested an "OEM" type replacement from parts express. Does anyone have experience with these?
Here is the exact speaker:
http://www.polkaudio.com/products/monitor4
Post edited by sjt_711 on
    F1nut Posts: 50,748
    edited August 2013
    Your speakers use the SL1500 tweeter. Have you checked with Polk to see if they have any?
  • sjt_711
    sjt_711 Posts: 3
    edited August 2013
    Well, I'm a bit confused on which tweeter is the correct one. Polk does carry the SL 1500 but I am not sure those are the correct ones. When I do a search of the Polk SL 1500, the one that comes up is rectangular and clearly says Polk Audio on it. The tweeters in the speakers are 3 1/4' square with a 3/4" speaker and there doesn't seem to be a name anywhere on it. I need some help!
    F1nut Posts: 50,748
    edited August 2013
    Remove the tweeter and look on the back for the model number.
    F1nut Posts: 50,748
    edited August 2013
  • PolkieMan
    PolkieMan Posts: 2,446
    edited August 2013
  • sjt_711
    sjt_711 Posts: 3
    edited August 2013
    Thank you PolkieMan. Those are the correct tweeters! I found a set of tweets and crossovers online for a fair price. ($35)
    This will leave me with an extra set of crossovers. Perhaps I'll recap them for the future....I love how a new project presents itself!
    Does anyone have a cap suggestion? Some say to replace the electrolytics with poly caps.
    Thanks guys and go team Mercedes!:)
  • StantonZ
    StantonZ Posts: 445
    edited August 2013
    Since the XO is so simple on the 4's, and they don't have the dreaded polyswitch, I actually left mine alone (I rebuilt the XO on my 10B's). Doesn't mean it wouldn't help, but I didn't have to "touch" mine at all because I'll never replace the peerless tweets. If you do end up replacing the parts, most folks here (including myself) go for SoniCaps and Mills resisters.
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • PolkieMan
    edited August 2013
    I would think too it would help the sound to replace the them SoniCaps and Mills and would not cost much either, those caps were cheap and now they are quite old.
