any suggestions?
g-unit
g-unit Posts: 6
edited March 2004 in Custom Fabrication
i have a 1991 ford thunderbird and the factory speakers in the back are 6x8's and i recently purchased some new polk 6x9 mmc690's and a pioneer 240 watt amp to push them. the speakers wont fit so i am going to need to make some modifications by cutting out bigger places for the speakers. does anyone have any advice or suggestions that might help with this opperation?
thanks.
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    edited January 2004
    check around...I know they make ring adaptors for just that... think crutchfield might have some...though not my fav. place
  • g-unit
    g-unit Posts: 6
    edited January 2004
    went to the website but the only thing they had that fits your description would be for putting smaller speakers in bigger holes. any other suggestions? thanks for the help ice.
  • TrappedUnder Ice
    edited January 2004
    well...if ya have a jigg saw...thats what i use to cut my metal in the car... done it many many many times....
  • g-unit
    g-unit Posts: 6
    edited January 2004
    yea, thats what im planning on doing...i was just checking around to see if there was an easier way.
    thanks.
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    edited January 2004
    theres an easier way...but it costs money to take it to a shop:)
    -Cody
  • g-unit
    g-unit Posts: 6
    edited January 2004
    ehh...ill do it myself......
  • MATTKNIGHT3
    MATTKNIGHT3 Posts: 29
    edited February 2004
    Hey, I dont know if you have access to a rotozip or not, but that is the easiest way to accomplish your task. You'll have to get a metal bit or a carbide bit, but it works best. You can adjust the depth that the bit will cut with the collar on the 'zip, that way you dont go cutting the back window up!
    Matt
    Home theater:
    Harmon/Kardon, Rotel, NAD, Panasonic, Polk RT 55i's, RT35i's and Csi40
  • TheAudioSpectru
    TheAudioSpectru Posts: 57
    Sounds like a goo job for the ole Dremel...
  • MTXMAN
    MTXMAN Posts: 682
    edited March 2004
    i use a dremmel with a carbon fiber enforced cutting bit....
    Hemi: (HEM -e) adj. Mopar in type, V8, hot tempered, native to the United States, carnivorous, eats primarily Mustangs, Camaros, and Corvettes. Also enjoys smoking a good import now and then to relax.
