center channel for SDA II
stray cat
I have an older pair of SDA II 's and would like some suggestions on a center sp. that will mate well with these speakers. Thanks for the help!!
Post edited by stray cat on
CS-400, CS-400i, or the CS-1000 will do the trick and leave you breathless...........:D
Happy Holidays,
Joe -
Thanks!! I've got a kenwood 4090 rec. on a sony 61 hi-scan with these speakers and it sounds pretty good to me. I can tell how critical a quality center channel is though, because the small DCM I'm using now sounds nothing like the polks with voices.
