Soundbar 5000 and Direct TV remote
scollette
scollette Posts: 1
I just installed the Soundbar 5000 and I tried to set it up where the Direct TV remote controls the volume through the learning feature on the soundbar without any luck.
I made sure I switched the remote over to IF, manual said RF wont work, signal before going through the learning steps.
Just wondering if there is any special steps I should do with the Direct TV (Genni) remote?
Thanks in advance for any help you can provide.
- Shawn
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited August 2013
    Hello Shawn,
    Welcome to the Polk forum. It's probably best to give the guys at Polk CS a call at: 1-800-377-7655, I'm sure they can be of help.
    Regards, Ken
  • bae1161
    bae1161 Posts: 1
    edited August 2013
    Any luck with figuring out a solution with DirecTV and the 5000?
