monitor 10b
brwnd83
brwnd83 Posts: 8
edited August 2013 in Vintage Speakers
Hello everyone, I'm new to the site so I figured of post my vintage setup. I have a pair of monitor 10b's connected to a pioneer sx-535 20watt receiver, I recently picked up the speakers on cl for dirt cheap, they sound amazing except for one of the 6503's being stuck but ill be ordering a new one asap. I currently have them sitting on a milkcrates until I have time to build them a proper stand. :mrgreen:
Can anyone advise on a decent receiver to push these to their full potential?
Post edited by brwnd83 on
  • Mystery
    Mystery Posts: 2,546
    edited August 2013
    Welcome!
    Those are very nice speakers but 20w is very low power.
    At least get something with 100 wpc.
    Adcom, Parasound, Carver etc...
    Wait for more suggestions.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited August 2013
    If you want it to look exactly the same as the good ones you all have to find one used.
    To give them the full potential:cheesygrin: you might as well get 300 WPC.
    I like new http://shop.emotiva.com/products/xpa-2-gen-2
  • brwnd83
    brwnd83 Posts: 8
    edited August 2013
    Thanks for the quick replies! I found a set of the 6503's with almost the same mfg date(within a couple month's) so hopefully they will match up nicely. Do you recommend the crossover upgrade on these? Or should I put my money into a better receiver?
  • PolkieMan
    edited August 2013
    Both are needed and well worth the money spent. The old ancient caps are probably almost bad by now
  • gmjungbluth
    gmjungbluth Posts: 232
    edited August 2013
    Congratulations!
    The rabbit hole is deep with Polk Monitors - crossover refresh, dynamat on the PRs and woofers, new tweeters, stands, re-seal the PRs and woofers with mortite or armacell, etc etc etc.
    The first thing I would do is use some JB Weld to glue your magnets in place so you don't lose any more woofers. Then crossovers.
    As far as amps go, the sky's the limit but I wouldn't spend hundreds on new amplification until you spend $5 on some JB weld and then maybe up to $100 on crossover upgrades. The Monitor 10s are relatively efficient (89db/watt/m) so you don't need huge watts to get them going. If you like vintage Pioneers, shoot for 60 watts and above - that's likely the SX-8xx series and above (828/929, 850.950, 880/980)
    When I had my monitor 10s with RDO-194s however I found that they were much more fun with more modern equipment. I had a Harmon Kardon 3380 with 80 wpc which really got them going. You can find those on CL for about $100. They sound great.
    Have fun!
    HT System:
    Marantz NR-1403
    Front: Klipsch CF-4
    Rear: Paradigm Atom V3
    Center: Boston Acoustic VR12
    Sub: Bowers & Wilkins ASW600
    2Ch:
    Restored Fisher 500C
    Yamaha P-500 Turntable
    Living Room:
    Harman Kardon 3380
    Restored Polk Monitor 7B
    Bedroom:
    Harman Kardon VR-3750
    Cambridge Soundworks Ensemble
    Polk PSW10
    In and out of rotation:
    KLH Model 6,
    Polk LSI7
    NAD 7100
  • StantonZ
    StantonZ Posts: 445
    edited August 2013
    I was so impressed with my XO upgrade that I wished I had done it sooner; I didn't mess with anything else (internally) except replace my old SL2000 tweets with RDO-194's (very nice). I don't even use stands: I use something called "tip toes" (which are similar to spikes on a carpet--just not permanent). Enjoy them!
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • jimsvm
    jimsvm Posts: 307
    edited August 2013
    Plan on spending a little more on crossover upgrades. But well worth the money. Vr3 is the man ..
    Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
  • boston1450
    boston1450 Posts: 7,671
    edited August 2013
    brwnd83 wrote: »
    are you looking to stay vintage receive 2 channel? Or to newer receivers ? The 10's need a tad bit of power. As stated above id agree on the 60wpc or more. i am powering mine with a vintage receiver also. I have NOT done upgrades. Last on my list. But sound wonderful. if you decide to keep that Pioneer try hooking some Monitor 5 or 5jr+ 's to that. You will be amazed at the sound. I have a little Sansui G2000 18 wpc and youd swear it was a BIG ARS system that fills a fairsize room no problem on stands & sounds awesome.good luck with search. Keep us updated & WELCOME.
  • brwnd83
    brwnd83 Posts: 8
    edited August 2013
    Thanks for the advise on the jb weld def don't want to lose another driver, any specific spot I should apply it? I would like to stay vintage for this setup, I think I may upgrade to the higher end pioneer sx-1010 or possibly Marantz hopefully cl will provide another deal, i should have all the parts for the crossover upgrade in a couple weeks just put the order in
  • boston1450
    edited August 2013
    The Pioneer sx1010 would be a very nice receiver & a beauty for sure :)
  • brwnd83
    brwnd83 Posts: 8
    edited August 2013
    For the fronts i have Pioneer htp200f's connected and its a major improvement on the sound, i bet with the 5s it will sound amazing so going to add them to the list
  • PolkieMan
    edited August 2013
    http://www.polkaudio.com/forums/showthread.php?128224-How-to-do-the-JB-weld-mod-and-not-make-a-mess
    brwnd83 wrote: »
