Amplifier & Receiver Questions
chiptouz
chiptouz Posts: 152
edited August 2013 in Electronics
First off I own a Denon 3808ci receiver. I am going to be buying the Emotiva XPA-5 here shortly. I plan on using my Denon Receiver for the surround rear channels. So.....here are my questions, and remember I have never used external amps before.
  1. So when I send the signal via the pre-amp out terminals of the Denon Receiver the internal amplifiers shut off for the channels that are sent to the Emotiva amp?
  2. Since I will be using only two surround rear channels of the receiver the rear surrounds will be getting the full 130 wpc as stated in the manual, i.e. with two channels driven?
  3. Is there any way ( or any reason to ) to use the Denon receiver front channel amplifier to power the surround rear? I think I read that they provide 140 wpc with only two channels driven.
Again noob questions here, but I have just been thinking about it.
Thanks again,
Chip
Sharp LC-80uq17u
Denon 4520ci Receiver
OPPO BDP-203 Blu-Ray Disc Player
Monster HTS 3600
Polk RTi-a7 (fronts)
Polk CSi-a6 (Center)
Polk TC-60i (Rear & Surround Rear)
HSU Research VTF3-MK4 (Sub)
Logitech Harmony elite (Remote)
Post edited by chiptouz on
  • BlueFox
    BlueFox Posts: 15,250
    edited August 2013
    chiptouz wrote: »
    [*]So when I send the signal via the pre-amp out terminals of the Denon Receiver the internal amplifiers shut off for the channels that are sent to the Emotiva amp?
    Probably not. When I used my Sony 7100ES as a pre, it still got hot even though none of the amps had a load.
    Most likely.
    Depends. If your Bluray is doing the decoding and connects to the AVR via analog cables then hook the rear cables to the front inputs. If you are using HDMI to connect to the AVR then you probably have to live with how the AVR decodes the channels, unless there is an option to assign channels to specific amps..
  • Habanero Monk
    Habanero Monk Posts: 715
    edited August 2013
    chiptouz wrote: »
    I don't believe they will shut off the internal amps. They will just not have any load connected. A way to test this is hook up the XPA to the Pre-outs and also connect a Multi-Meter set to AC Autoranging and see you you still have voltage coming out of the left or right mains speaker terminals on the AVR.
    chiptouz wrote: »
    [*]Since I will be using only two surround rear channels of the receiver the rear surrounds will be getting the full 130 wpc as stated in the manual, i.e. with two channels driven?
    Yes
    That is the way the user guide reads: 130 W + 130 W (8 Ω/ohms, 20 Hz ~ 20 kHz with 0.05 % T.H.D.)
    chiptouz wrote: »
    With HDMI each channel is receiving it's own discrete signal and the AVR routes accordingly. You will have to wire off the rear surrounds. It's only a 10 watt difference. You won't notice so there is nothing to gain.
  • chiptouz
    chiptouz Posts: 152
    edited August 2013
    Thank you both for responding. I appreciate it.
    Sharp LC-80uq17u
    Monster HTS 3600
  • boston1450
    boston1450 Posts: 7,758
    edited August 2013
    I am very interested in hearing how you like it when you get it all set up. I really like Denons when it comes to HT with amps. Good luck n hope it works out well
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • chiptouz
    chiptouz Posts: 152
    edited August 2013
    Randy,
    Probably be in the next couple of weeks. I will post back. As part of the deal the wife gets a new painted family room and kitchen, that along with upgraded diamond earings. This amp may be more trouble than it is worth! :)
    Chip
    Sharp LC-80uq17u
    Monster HTS 3600
  • deronb1
    deronb1 Posts: 5,021
    edited August 2013
    chiptouz wrote: »
    Randy,
    Chip
    Yup, new car in the driveway here.
  • chiptouz
    chiptouz Posts: 152
    edited August 2013
    Glad to see that I am not the only horrible negotiator here! :lol:
    Sharp LC-80uq17u
    Monster HTS 3600
  • deronb1
    edited August 2013
    chiptouz wrote: »
    The only negotiations goin on were what color to get.:rolleyes:
