RTI A3 Fronts with a TL3 center?
DrunkMonkey
DrunkMonkey Posts: 1
edited August 2013 in Speakers
Looking for a little advice here. I currently have a pair of RTI A3s that I plan to use as fronts and I have 4 RC80i already mounted in the ceiling for surround. I'm ready to add a center channel, but space is limited. Ideally, I would go with something like the CSI A4, but that is just much too large for the space. It appears that the TL3 center would fit nicely, but I'm curious if it would be a good match with the RTI A3's. Anyone have a similar setup? Are there other center speaker options that I should consider instead?
