Broke my Triton power conditioner last night
BlueFox
BlueFox Posts: 15,250
edited August 2013 in Electronics
Last night I was playing the system at an obscene level when the power went off. At first I thought the breaker on the dedicated 20 amp circuit tripped, but it was okay. It turns out the Triton switched off. After turning it on, powering up everything else, it started buzzing, a really loud buzz. Prior to this, it was dead silent.
After troubleshooting this morning, I determined it is a load related issue. It only starts when both amps are on. Turn either off, and it stops. While half a stereo is better than no stereo, I can't live with that.
The first thing I did was replace the Triton with a Panamax 5300, which has both a voltage and amp meter on it. After powering up the amps, it indicated they draw 7 amps at idle. Then I remembered I recently put a Hydra AV in my HT, so once again I went through the ordeal of swapping power conditioners, and the two channel is now using the AV, and the HT got its Panamax back.
I emailed Shunyata customer service and hopefully can get the Triton sent back next week for repair. I think once I get a few extra dollars I will buy another Triton, and use one for the amps, and the other for everything else. This will provide me with a spare in case this happens again.
Two channel gear which caused the issue.
Pass Labs X600.5 amps (2)
Pass Labs XP-20 pre-amp
Bryston BDP1 digital file player
Bryston BDA2 DAC
Sony XA-5400ES SACD player
Aerial Acoustics 7T speakers
All cables are Shunyata Zytron models
The music was rock, and the pre was in the 70s, but I didn't measure the SPL. It was loud, but sounded great.
While disappointed, I realize that things break. At least I have the Hydra AV to fall back on, and this isn't as big a problem as when one of my previous amps broke.
Post edited by BlueFox on
    F1nut Posts: 51,904
    edited August 2013
    Doo doo happens. I would be interested to know what caused the issue.
  • headrott
    headrott Posts: 5,496
    edited August 2013
    Ditto.
    Glad you are able to listen to the system though BF.
  • BlueFox
    edited August 2013
    Same here. One of the features of the Triton technology is it is completely passive, no active components in it. Other than maybe the surge protection device. I also posted this in the Shunyata section of AudioAficiando, and the founder of Shunyata answers questions, and provides insight into power related issues. Hopefully, he will chime in.
  • headrott
    edited August 2013
    Was it too much current or voltage draw maybe? I would guess current more than voltage. I'm sure you know them, but here are the specs:
    Maximum Voltage: 130 VAC (non regulated)
    Maximum Continuous Current: 20 Amps
    Maximum Instantaneous Current: >100 Amps (8 ms)
    Over voltage surge suppression: 20,000 Amps
    Over current protection: Hydraulic Electromagnetic Breaker
    Dimensions (WHD): 17"x5.7"x16.3"
    Weight: 38 lbs
  • BlueFox
    edited August 2013
    headrott wrote: »
    I don't know, but your guess is reasonable. These amps eat current like Wimpy eats hamburgers. It still works fine, except for the buzz. It will be interesting to find out the problem.
  • BlueFox
    edited August 2013
    I received an email tonight from the founder of Shunyata. He said the vibration noise is from the electro-magnetic breaker that tripped when I was blasting the system. It is designed to trip at a little less than 20 amps, and he suggested I get another line just for the amps. I might do that, but also get another Triton, and distribute an amp on each line. The rest of the gear is low current; a Bryston BDP1 digital file player, Bryston BDA2 DAC, Pass XP-20, and a Sony XA-5400ES SACD player. When the Triton tripped, the Sony was on, but not in use.
    Anyway, I should have it back by Friday, and good as new.
    F1nut Posts: 51,904
    edited August 2013
    You should be able to reset the breaker yourself, if it happens again.
  • headrott
    edited August 2013
    ^^^Yeah I would think so^^^ Glad it wasn't anything that needed to be replaced? Or, was it a one time trip electro-magnetic breaker?
  • WLDock
    WLDock Posts: 3,073
    edited August 2013
    I would guess you purchased the Triton with the thought that it was a power distribution system capable of dealing with the Pass amps...why would you need two of them? They make a bold claim:
    ** None of the Hydra models limit maximum current and all are rated a 20 amps continuous with 40-50amp peak current available. There are NO internal limitations to peak or continuous current in ANY Hydra model. All Hydra models are measured to test and ultimately prove their efficiency in current delivery to ANY complete high-current system, amplifier, projector or recording panel!
    Your Pass amps output is rated at Peak: Maximum Volts= 99 / Maximum Amps = 36 ~ 3564 watts. They are for sure Beasts! However, loud music or not, I'm sure you were not even close to the max rated output power of 1200 watts @ 4 Ohms.... The power compression of your speakers would let you know.
    Everything breaks! We all know that. However, it seems one would want to know why did the unit fail? It would seem that a single unit should be able to handle both amps based on their claims. Getting another unit is one way of dealing with it...
    Why not get the repaired unit back....and instead of spending more coin on another unit that did not meet its claim....get a revenue grade meter for your stereo line and blast the system again and see what your peak volts and current reading are. Then if it fails again...the conversation with Shunyata should be interesting. Heck, I would get Pass involved as well....what are their thoughts and recommendations?
  • BlueFox
    edited August 2013
    Resetting the breaker isn't an issue. After tripping, and resetting, it started giving a loud buzzing/vibrating noise with current going through it. All I had to do was turn both amps on, and once they reached idle it started buzzing. Prior to the trip, the Triton was utterly quiet. The amps run in class A up to around 100w, and together pull 7-10 amps at idle. Personally, I suspect it was just a weak, bad breaker, and the replacement should be fine.
  • BlueFox
    edited August 2013
    So, I responded to his email last night, and mentioned that if I owed anything then have the CS rep contact me, and I will gladly pay. After all, usually you at least have to pay shipping back for repair. They had UPS come by the house and pick it up, no charge. Anyway, this is the first line in his reply this morning.
    "First, we never charge for a repair of our products even if they were out of the warranty period, which yours is not."
    Time to break it again. :twisted:
    Only kidding. I have no need for music as loud as it was when this happened. I'm surprised the speakers didn't go up in flames.
  • zingo
    zingo Posts: 11,258
    edited August 2013
    BlueFox wrote: »
    I hate anything similar to that noise, and you really can't turn it off fast enough, even if nothing is being damaged. It sounds like Shunyata is taking care of you which is all that matters.
  • BlueFox
    edited August 2013
    Just received my repaired Triton power conditioner with a new breaker. It is installed and working like a charm. Other than music, I can't hear a thing, which is how it should be.
    Aside from being inconvenient, this didn't cost me a penny, and wasn't a bad repair experience. Shunyata had UPS come by and pick it up. The founder contacted me via email to let me know what happened, and it was fixed and shipped back the day after they received. They even included a set of spikes and saucers as a gift. So, now I can rave about how well their cables and power conditioners work, and rave about their customer service when the rare incident happens.
  • drumminman
    drumminman Posts: 3,396
    edited August 2013
    Was the issue something besides the breaker? Wonder what was causing the buzzing noise and what the repair consisted of.
  • BlueFox
    edited August 2013
    drumminman wrote: »
    Caelin said the breaker was generating the noise, and the more current through it, the louder the noise. The Pass amps, combined, draw over 7 amps at idle, according to the amp meter on a Panamax 5300, and once they came up to idle the noise was very obvious. They replaced the breaker. Everything else in a Triton is passive, but I suppose it is possible another part could fail.
  • BlueFox
    edited August 2013
    While I can't prove it, I swear the Triton sounds better after repair than before I broke it. Maybe my amps are settled in after whatever number of hours they have played since I got them last month.
