Is this Amp ok for my 10" momo subs
Systems
I just got 2 10" polk momo subs with 300watt peak handling and i got a rockford 900watt amp to hook up to them? i was wondering if that amp would be ok or too much?
Testing
Testing
Testing
Testing
Testing
give us the model number of the sub and the model number of the amp, then well help
just saying i have a 900 watt amp doesnt help
i have an amp that peaks around 1600 but i wired it to where its putting out 400...
-Cody -
hey, the model number for the subs are polk mm2104 and the number for the amp is RFKD301s. I just wanted to know if that amp would put to much power to the subs or if it would be ok. THANKSTesting
Testing
Testing -
that amp will only drive one of those subs
you either need to get a bigger amp or buy another 301s
-Cody -
Are you sure? The place where i got them said that amp would work for for them. How much power is each sub taking?Testing
Testing
Testing -
Check the manufacturer spec's for the MM2104=
Power Handling (continuous) 300 w
Power Handling (peak) 600 w
http://www.polkaudio.com/car/specs.php?name=mm2104
The box shows 300W peak but it is wrong.
Take a look about it at this link:
http://www.crutchfield.com/cgi-bin/S-z2BMjEFb9Wy/ProdView.asp?a=0&s=0&cc=01&g=67600&id=detailed_info&i=107MM2104#Box%20Correction
-GLopez -
hey, thanks. What size amp would you hook up to them for the best performance? Cause i get this installed on the 14 so i have time to get a new amp.Testing
Testing
Testing -
you want an amp with a rating of 600x1 @ 2ohms RMS
if you want to stick with Rockford Fosgate, then get the 601S
heres a link
oo, and just out of curiosity, who told you that amp would work with these speakers?
-Cody -
i was wondering since those subs are goin to take a bigger amp and i really don't want to buy a bigger or another amp since this is my first system i was wondering if you could tell me if i could hook up two of either of these rockford subs to my amp i have now. the sub models are RPF4410 or RPF4810. thanks.Testing
Testing
Testing -
buy a JBL BP 600.1 --- its like 170 bucks on ebay -- bring back the rockford 301S -- you'll probably break even.The Artist formerly known as PoweredByDodge
