setup advice
paul mx3
at the moment hy system consists of a kenwood z920dvd h/u...alpine h700 processor...jl 500/1 running poll mm100 sub....i have a set of mm455 comps and i want to biamp them ....i have a jl 300/2 and a us amps 600tu......i know its slightly overkill with the amps but i want plenty of headroom.....do you think the us amps tube amp would be better to run the mids possibly giving a more mellow sound and the jl 300/2 on the tweets.....also what crossover frequencies do you find seems to work better with the mm455 comps...
Post edited by paul mx3 on
sounds ridiculous to me... that's way too much power... a 90 x 4 would be better for the bi-amping... running straight something like 150 or so is peachy keen.
i think you've got a good idea, but the whole "use whatever is laying around" method never works well for that.
use teh 300/2 for the mids.... get another amp (preferably JL so they all match) that's like 75 x 2 or 90 x 2 to run teh tweets off of... make it all pimp dude...The Artist formerly known as PoweredByDodge -
that was my origonal plan...but my thinking regarding the us 600 tube amp is that im hoping if i run that on the mids it should hopefully give a lightly more mellow sound to the mids...like i said i know its complete overkill with the amount of power at my disposal using these amps but im aiming for an sq setup and i want to run the amps well under there capabilities....
my thinking is that origonally i was told by polk that the components would run well passively off the jl 300/2 but if i run it actively using what is in effect 2 150rms per channel amps im still basically giving them the same power? -
I would say just run the comps off the 300/2. Its plenty powerful and plenty capable. Running it solely will sound just fine. JL are excellent SQ amps so you will be happy.
As far as I know, the only advantages to running bi-amped systems would be to get moer power or to crossover a particular amp to a specific frequency.
Having 300 watts to each left / right channel is total overkill. you would never even come close to using all that power. With the JL's 150 x 2 I doubt youd ever use anywhere close to all of it either, unless you were providing all the sound for a block party or something.
Try the 300/2 on the comps and see for yourself. I doubt youll be unhappy.polkaudio sound quality competitor since 2005
