As promised or bone to pick w/ you about SDAs
leftwinger57
leftwinger57 Posts: 2,917
edited August 2013 in Speakers
So I got my gov't dole and in fact did apply a first coat of a satin clear poly finish .No pictures you know what it looks like already and not much has changed. So they will get another coat or 2 once dried I'm not sure if I should light sand in between I really don't have the patience for this any more.Now ,some of you dudes ragged on me for using Pledge on the front motor boards and rears not the good stuff or tops.So what are these things made of MDF?In my world MDF is a wood product which = cheap furniture=a dash of Pledge.It's not acetone, turpentine,or bezine, it's Pledge.What is going to happen? Are mushrooms going to sprout out of these things.Listen, as they they say in DA Bronx it's my football so leave it there.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    edited August 2013
    What are "front motor boards"?
    SDA SRS 2.3TL's
    SDA 2B TL's
  • leftwinger57
    edited August 2013
    I thought that what the fronts are called that house all the drivers and passives. That's what they call them over on the Klipsch site sounded good at the time.
  • deronb1
    deronb1 Posts: 5,021
    edited August 2013
    Never heard that before. Kinda makes sense, I guess.
    pitdogg2 Posts: 27,066
    edited August 2013
    one word ...silicone
  • leftwinger57
    edited August 2013
    Hopefully you will a nice sheen on the topps and sides and underlip of my 2 beauts. So far 2 coats w/ no sanding in between.Jeese was Absolutely right that they needed a protectorant from the tops drying out and I knew this but just had to wait a bit .I w/o a doubt like the new sheen and maybe invest in another coat or 2.Enjoy.
  • jimbo1421
    jimbo1421 Posts: 772
    edited August 2013
    The silicone in Pledge causes a contaminant problem called "fisheye" if it gets into newly applied finishes. It is best to keep it out of the house altogether if you ever intend to refinish anything.
    More info: http://www.google.com/search?safe=off&sclient=psy-ab&q=fisheye+finish+problem&oq=fisheye+finish+problem&gs_l=serp.3...6225.19460.0.20236.23.21.0.0.0.0.0.0..0.0....0...1c.1.23.psy-ab..23.0.0.Mc0BMImLfv8
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    Parasound P3 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
  • leftwinger57
    edited August 2013
    That's very informative but for the 19th time I did not touch any part of anything I refinished. I just wiped the fronts and backs w/o touching any of the speakers .surrounds or screws .I have an absolutely perfect finish of black paint or whatever they originally used .No streakes,no fish eye or any other detrement these wonderful speakers.That's why I again took shoots of the fronts to prove the point that nothing happened. No one is winning this one but me.
    F1nut Posts: 51,793
    edited August 2013
    Lew,
    As I stated in your other thread, silicone migrates (spreads), which means it could possibly end up contaminating your end caps, electrical connections, etc. even though you only applied it to the front and back. As jimbo1421 stated, best to keep it out of your house. Other problems with silicone on furniture is it smears when touched and acts like a magnet for dust, dirt and grime.
    The front bezel on your SDA's is vinyl covered particle board. Only the TL models have MDF bezels, which are also vinyl covered. The back should be vinyl covered too, but IIRC, early SDA backs where simply painted.
    I'm not ragging on you, just trying to help.
  • leftwinger57
    edited August 2013
    Jesse, By now you must know that I respect what you say w/ all your advice. You were absolutely right on the point that they needed a finish .Ok again I will relent I will wipe them down maybe after all is dry and not apply anything.I really do not remove the grill covers all that often so there really is not an urgent need to clean them like dressers and armoirs.You got admit that I'm stubbburn mule of a dude and if there is an inkling of me being right until proven wrong I go w/ me.Thanks again Pledge is OUT!!!.
    F1nut Posts: 51,793
    edited August 2013
    It's all good Lew, always was.
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited August 2013
    What about Murphy's Oil Soap? Safe to use? Or best to avoid?
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
    F1nut Posts: 51,793
    edited August 2013
    Good question.
    Would you consider applying vegetable oil to your furniture, floors or speakers? Of course not.
    Well, Murphy's Oil Soap is a vegetable oil and potassium hydroxide (think lye) based product. That alone should be enough to stop anyone from using it, but in case it isn't, the fact that using it involves a lot of water should. Water will find any scratch, crack, etc. in the finish, get under it and cause delamination.
    My suggestion, throw it out with the garbage.
  • HTguru1982
    edited August 2013
    Ah, you guys are tough on this stuff lol. Out it goes...
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
  • leftwinger57
    edited August 2013
    You must go w/ the pros.I have bowed my head so many times already I can't straighten it out any more ..DO NOT TAKE WOOKWORKING ADVICE FROM ME. Ask those other guys.....lololoololol
  • nspindel
    nspindel Posts: 5,343
    edited August 2013
    The guy who did my wood floors gave me the exact same advice as Jesse. Take the Murphy's Oil Soap and throw it in the garbage. He told me that if he needs to do work on the finish of floors where Murphy's was applied, there is no choice but to sand down to bare wood and start over, whereas otherwise you can often just do a light screening and apply another coat of poly. He told me 17 years ago that the best way to clean a wood finish is 1/3 white vinegar a d 2/3 water. 17 years later, the floors still look great.
    tonyb Posts: 33,072
    edited August 2013
    Speaking of speaker cabinets, what's the best for weekly cleaning that won't harm the finish ? Jesse, that's aimed at you bro.
    F1nut Posts: 51,793
    edited August 2013
    A slightly damp soft cloth to pick up the dust and if there's any moisture left follow up with a dry soft cloth. Endust applied to a soft cloth also works.
  • leftwinger57
    edited August 2013
    I think thia is where it ends on the wookworking side of things. 3 coats of Minwax clear satin poly.Let dry in between coats and I really like the results. I know cables will be on the agaenda as soon as some mad $ comes in.I threw one pix of stain before any treatment was done. They look and feel great Any descrephincy you might notic is just the light of the sun coming in .They are the same colors
