Rotel RCD855 DAC or Grant Fidelity TubeDac09 ?
stretchl
Just got my old Rotel out of the shop and hooked it up. It sounds pretty good!
Right now I'm running it directly into my Yaqin MC-10t, but I wonder how it might sound using the TubeDac converter?
Just thinking out loud... anyone join me?
“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
- Isaac Asimov
Hi-Fi
Visuals
Post edited by stretchl on
It could sound better, but there is only one way to find out; especially since you already own it. :cool:
Have you tried the Squeezebox with and without the TubeDac? -
I have both of these units but have never tried them together. The Rotel does sound very good using the internal DAC. I'd have to look, but I'm not home now. Does the Rotel have a digital out? I didn't think so, but could be wrong.
I have a Squeezebox in my main system connected to a Music Hall dac25.2 and it sounds excellent.Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
What I really want to do is as direct a comparison as possible between streaming Apple Lossless files with the Squeezebox on the one hand, and playing CD's with the Rotel on the other.
Zing, I've not tried the SB without the TubeDac but that's a good idea. Will be fun to try. Honestly, and this is embarrassing to admit, I didn't try the Rotel with the TubeDac b/c the only decent quality digital cable I have is super short (from the SB to the TD), and I'm too cheap to just buy another.
Carl, there is a digital out on the Rotel.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
http://Vimeo.com/channels/stretchphoto -
Your amp can suggest multiple inputs, so plug both in, cue up the same song as close as possible, and just switch back and forth. Then plug the TubeDAC in-between one and repeat test. Then do the other component, and see what combination you best prefer!
First - I'm proud apparently have your 10,000th post on my thread.
Second - I did that last night, but unfortunately I don't have a proper remote, so I had to stand beside the hardware and flip the switch. As soon as we can get a few minutes free from our two year old, I'm going to enlist my wife to flick the switches, while I sit in the listening chair. Then we shall see!
- Isaac Asimov
Hi-Fi
Visuals
