How to remove part from chassis that is glued...??
starkiller
starkiller Posts: 2,723
edited July 2013 in DIY, Mods & Tweaks
Got a replacement set of touch switches for my DAC to replace the one that broke. But it looks like i need to remove some glue before replacing the switches and i have no idea whatsover how to do this except maybe with a hair dryer to loosen up the glue a bit.....I am nowhere near being a DIY!!:redface:
See pics of the replacement part and the glued in part it will be replacing, hopefully....
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
  • Systems
    Systems Posts: 14,872
    edited July 2013
    I can't make out heads or tails from those pics.
    First pic looks like a dash out of a '53 Nash Rambler.:lol:
    No idea as to glue type?
    Does it look like hot glue, I can't tell from the pics.
    Try a Q-tip with some alcohol, soak around the "glue" mounting points, may have to apply it more than once.
    Testing
    Testing
    Testing
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2013
    Heat gun?
    Main Surround -
    SCompRacer Posts: 9,152
    edited July 2013
    You can try freezing the part first and then try and remove it. Try a thin blade screwdriver or sharp thin scraper to pry the parts apart. Just remember too much force and you can deform the face plate. Sometimes a razor blade works well to get between the parts but use one of them razor scrapers; if you push a single edged blade with your fingers and slip/blade flips, you're gonna bleed and need the hospital.
    EDIT: You can do a search and find more details about the freezer method.
    mhardy6647 Posts: 35,376
    edited July 2013
    Heat and/or cold are both excellent suggestions. Go easy with the first; with the second (and I am not kidding!) colder is better... do you have access to dry ice pellets? Liquid nitrogen?
    Next place to go if neither approach works out would be solvents... Ethanol is probably too polar; acetone is next on the lise; xylene (the principal component of "Goof-Off" paint splatter remover) would probably be my next choice, followed by toluene then we get into naptha/lighter fluid... (from more polar to less polar; just like organic chemistry class!).
    pitdogg2 Posts: 27,556
    edited July 2013
    would Methyl Ethel Ketone be too aggresive I have used it to remove glue on speaker baskets and corrosion on PCB boards.
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited July 2013
    MEK will dissolve some plastic. I wouldn't use it.
    edited July 2013
    Pretty similar to acetone (which is dimethyl ketone); as noted above it will attack some plastics, so proceed with extreme care if any sort of plastic is involved.
    Starting with chilling or heat is really an excellent and pretty safe place to start!
  • zingo
    zingo Posts: 11,258
    edited July 2013
    The freezer would be my first choice, with light heat if that doesn't work; and either method might need a little help from the above mentioned small screwdriver or flat blade.
  • starkiller
    edited July 2013
    Will try the freezer way first as the button assembly is all plastic and with peripheral neuropathy in both hands and fingers using a straight blade is iffy at best :eek:
  • unclebump2008
    unclebump2008 Posts: 10
    edited July 2013
    Dremel tool with a cutting tip and grind it out very slowly.
  • zingo
    zingo Posts: 11,258
    edited July 2013
    starkiller wrote: »
    You may have to try dry ice if the freezer doesn't work.
  • starkiller
    edited July 2013
    Hey Hey Hey! Got lucky for a change and was able to use a small flat-head screwdriver :) Now i have to go out and buy some super-glue as we don't seem to have any around the house and I don't think Elmer's would work that well :mrgreen:
    Thanks for everyone's help!
