need help with amp for MM12
91'MOMOGTi
ok i know that the MM12 is a 4ohm sub, and that i want to install the momo C500.1 amp with it. but it only pushes 350 watts at 4ohm. could i safely run a single MM12 on a C500.1 @ 2ohms?
if this is possible how would i run the wiring? i mean the sub only has one set of wire connectors. so i wouldnt be able to wire it the way the polk website shows for 2ohm on 1 sub.
other than that if i were to run both subs in parralell to acheive a 2 ohm load on the amp as the polk site shows in the wiring diagrams section. would this give 500 watts total? meaning 250 watts to each sub or what? im confused with all of this and im new to the car audio world, so basicly all im asking is how can i get 500 watts to each of my MM12 subs using carbon series polk amps?
Post edited by 91'MOMOGTi on
two momo mm12's on a c500.1 will give you 250 to each sub.... 500 total.
my suggestion is to get a C300.2 for each sub... if u run one momo mm12, get one c300.2 -- bridge it to the sub and you'll get over 500 watts to the sub... which is what you want.The Artist formerly known as PoweredByDodge -
thanks i was having trouble figuring that out. do you know if there is a diagram for how to bridge the C300.2? i dont fully understand this concept yet. all of the diagrams i saw where of the C500.1
ok i went and looked at the pdf for the C300.2 i just hook up the right amp positive to the speakers positive, and the left amp negative to the speakers negative?
sounds right to me
-Cody -
cool thanks guys...
hey - yup - sounds good to me.The Artist formerly known as PoweredByDodge
