Replacement driver for MW6500 in Monitor 10A
lanteau
lanteau Posts: 4
edited July 2013 in Vintage Speakers
I just called Polk and ordered a replacement driver for a seized MW6500 in my Monitor 10As. He told me the replacement is a 6502 so I went ahead and ordered it.
I did some research and it looks like the MW6502 is a 4ohm speaker, the 6500 is an 8ish ohm driver. I called back and asked and got a different representative. He says Polk doesn't make *ANY* MW drivers anymore, and any new replacement is from their R-something series and the 6502-2 is the correct replacement for the MW6500 I have. I asked him if it was 8 ohms and he said yes.
I'm still not feeling so confident about this replacement, should I trust him or did I get the guy that doesn't know what's going on?
Post edited by lanteau on
  • lanteau
    lanteau Posts: 4
    edited July 2013
    I believe he told me it would be a RD6502-2.
  • lanteau
    lanteau Posts: 4
    edited July 2013
    My instict was right, I called back and asked for Helen this time. She told me if I measured the MW6500 at 7.something ohms then I need a 6503. She was able to modify my order.
    So now I'm another believer, if you need help, call CS and ask for Helen!
    pitdogg2 Posts: 27,308
    edited July 2013
    lanteau wrote: »
    Kim is another both are the shiznit
  • Mystery
    Mystery Posts: 2,546
    edited July 2013
    I measured MW6500 from 4A's and they measured 7.6 and 7.7.
  • lanteau
    lanteau Posts: 4
    edited July 2013
    Mystery wrote: »
    Yeah exactly. Pretty sure the MW6502 would have came in somewhere around 3.5 which wouldn't be right for the 10A. Especially since the two drivers are in parallel.
