50W enough for db6750?
Systems
Does anyone know if 50W from an MTX amp per channel would be enough to power the db6750 component set well? I read in a newsgroup post that 50W would not be enough.
Thanks,
Tri
Thanks,
Tri
Testing
Testing
Testing
Testing
Testing
I would consider it to be the minimum. Im running 40 watts to my MMC690s and its enough but thats it. I will eventually upgrade to a higher end, non-budget amp and will get something in the 70-80 watt range. To a point, more power doesnt necessarily mean louder. Some speakers need a little more grunt to make them work better. Give them too little and youll never get the full potential they have to offer. Its like buying a Corvette and just driving it to the grocery store on the weekends. Youre missing a lot!
I would say use the MTX for now and it wont hurt them, but start saving your pennies for a 75-100 watt amp in the future. It will bring out the best your speakers have to offer and youll be short changing yourself until you do.polkaudio sound quality competitor since 2005
