Explorer Stock Setup
Systems
Hey guys, great forum. My question is this. I have 96 Eddie Bauer Explorer with the premium JBL stock stereo. It had a 6 inch sub in the back that was already crossed over through the stock amp, which is really weak. Is there any way that I could take advantage of the already existing connections to the stock weak amp? Maybe I should rip apart my trim and look before I ask, but I thought I'd try. BTW, I just got 2 mm120's in a sealed box. Thanks
Testing
Testing
Testing
Testing
Testing
