Need 1 MW7200 for RTi38
vcwatkins
Looking for one, preferably used, MW7200 for a frozen RTi38.
Thanks,
Craig
Thanks,
Craig
Post edited by vcwatkins on
There's a 7203 on here right now. Should be essentially the same woofer:
http://www.polkaudio.com/forums/showthread.php?149596-Cleaning-House-LSi7-CSi5-CS400ix2-RT800i-MW7203-SL6506Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
Thanks, guru. Not sure these are worth $120ish (bt for $50). Guess I'm looking exclusively for used.
CraigBeach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Any opinions on how RT55 MW's might work/sound?Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Ended up buying a new mw7200 from Polk which wasn't too bad after the CP discount. Thanks again guru.
Glad you got it worked out.Display: Sony 42" LCD
Fronts: NHT 2.5
Center: NHT VS-1.2A
