Need help with a old turntable my grandfather gave me...
c_corie
c_corie Posts: 138
edited July 2013 in 2 Channel Audio
He wasn't using it so he gave it to me. It's a late 60's? Weathers ML-66A with a Pickering XV-15 Cartridge but it has no needle? I'm new to vinyl...the table appears to turn, I'm assuming I just need to get a needle that fits and be on my way? My Marantz PM6004 has a phono stage which I assume will work for now.
Post edited by c_corie on
  • thsmith
    thsmith Posts: 6,082
    edited July 2013
    I believe Snow is selling some NOS stylis's in the flea market. But to answer your question yes, you need a replacement stylis or new cartridge.
  • pglbook
    pglbook Posts: 2,228
    edited July 2013
    I'd also recommend that you get the tt serviced and checked out since it has not been used for a long time. It would be a good idea to get it cleaned, calibrated, lubricated, etc. And (unless you know how to do it yourself) you should have the new cartridge/stylus mounted and tracking checked, etc. Although it appears to play ok, if you use it and things are off kilter in some way, that is a good way to damage your vinyl.
  • c_corie
    c_corie Posts: 138
    edited July 2013
    pglbook wrote: »
    It has a needle/stylus I didn't realize how tiny it was...LOL
    He also gave me a gauge to measure tracking force, but I'm not sure what it should be? I assume tracking force is the really what could cause damage to vinyl.
    mhardy6647 Posts: 33,964
    edited July 2013
    There is a cartridge database with specifications for hundreds of cartridges at www.vinylengine.com
    The Weathers is an older machine but should be very well made and very capable. Post a photo if you can and if you want to.
  • George Grand
    George Grand Posts: 12,258
    edited July 2013
    Weathers had an audio shop about 15 miles from here. Long gone.
  • strider
    strider Posts: 2,568
    edited July 2013
    Surplus Sales of Nebraska has parts for Weathers turntables:
    http://www.surplussales.com/Equipment/weathers.html
    Wristwatch--->Crisco
    edited July 2013
    strider wrote: »
    Whoa that is so cool! How could I not have known this?! I have looked at their website many times before, but failed to notice this...
  • George Grand
    edited July 2013
    How could I not have known this?!...
    Cause you're not as cool as Ben is.
    edited July 2013
    Nail head has been met by hammer.
    I want some of those arm blanks...
  • xjghost
    xjghost Posts: 1,104
    edited July 2013
    I got my Needle for my techniques at the Needle Dr. I did not know what cartridge I had or what needle I needed. They had me photograph them and email the pictures then responded very quickly as to what I needed. I highly recommend them. http://www.needledoctor.com/
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
