Any experience bi-amping Monitor 10s?
kestrickl
I have a pair of Monitor 10Bs that I bought a few years ago. I replaced the SL-2000 tweeters with the RDO-194s and am quite happy with the Monitor 10s, especially after setting them up with a subwoofer driven by a two-way stereo active crossover and power amp. However, I am never one to leave well enough alone, and I am looking at doing a crossover upgrade by putting some sort of film capacitors in the crossovers. Before doing that, it came to me that I already have an extra stereo power amplifier and a 3-way stereo active crossover that are begging to be used. Instead of upgrading the crossovers in the 10Bs, I could power the tweeters separately from the 6503s, crossing them over at about 3-4 kHz with an 18 dB/octave roll-off rate rather than the 12 dB/octave of the existing crossover. Has anyone on this forum done this before? What kind of problems do folks think I will run into doing this? It would actually be less additional expense for me to go the electronic crossover route than to go buy some nice film caps.
Post edited by kestrickl on
No, but I just rebuilt my XO's and am very pleased with the results. My recommendation would be to NOT bi-amp and rebuild the XO: less trouble in the long run.Yamaha RX-A2050 AVR (5.0.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets
Replacing the caps and resistors would be more predictable. Looking at the crossover schematic for the 10 models, it looks like there is a filter in the tweeter XO section that provides a mild equalization ramp to correct for the tweeter response. I would have to do something like that with an equalizer if I went the biamp route. Not a big deal, but it would tie up some equipment that I could put to some other project. I will probably decide after I replace the caps in a pair of Monitor 4.6s that I am using in my basement system.
Welcome to the forum! Be very careful with your choice of words. Just the mention of an equalizer on this forum could get you burned at the stake and your ashes thrown into a septic tank.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
If you only knew the kind of project I have in mind for the power amp and active crossover if I don't use them on the Monitor 10s. Probably would get me burned at the stake around here. Pay no attention to the fact that some of the elements in good crossover designs are used in an attempt to correct speaker driver frequency responses.
"Equalizer"
Catch me if you can!cristo
NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
(with Sonicraft/Solen/Mills crossover rebuild) -
If this "experiment" is at no $, go for it!
if I read your first post correctly, your EXO is 3rd order, passive-2nd order. XO your tweets fractionally below the passive frequency and listen, listen, listen.
If you don't like, buy the film caps & be happy.
TonySamsung 60" UN60ES6100 LED, Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga: LCR mids “Foamed & Plugged**”, inside* & out
*soldered **Rob the Man (Xschop) LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & Mids - 981, connected w/Monoprice Premiere ICs
Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s
