Setting up sda2.3
old19
old19 Posts: 1
Need some advice, I have sda2.3's . This is my first experience with a speaker with two inputs I have a pretty good understanding of the hook up but. Can I use my Mac 7300 and Mac2105 for this purpose. My pre-amp Mc-32 or Mc-26? I have a Marantz 250 amps and a Marantz 3200 pre. I have a Nad c375bee int. amp I'm using for my Sda1 and Sda2's. any suggestions?
Post edited by old19 on
  • drumminman
    drumminman Posts: 3,396
    edited July 2013
    The most important consideration is you must use an amp that is common ground if you plan to use the IC cable connecting the speakers to each other (the only way to get the SDA effect). As far as the two inputs per speakers you can use jumper wires to connect them and then connect speaker wires from your amp to the lower inputs.
    Are the 2.3TL's ?
