Anyone know the pin out on the Technics TT?
So I have a couple of Cardas 5 pin DIN's on hand here and am wondering if the pin out is the same as the Grace Tone Arm pin out?
Not much info on the net as regards to the Technics.:redface:
I know the Grace pretty well (thanks Dromunds
But are they the same pin out?
Not sure if it is the same on the Technics?
Wanting to build a couple of 5 pin to dual rca's (I gots the KILLER:biggrin:) but am at a loss as far as the Technics pin out goes?:twisted:
Anyone?
Mark, Rich,Carl, Kenneth?
Anyone?
No, I'm afraid not, you might have to trace the continuity from head shell to connector with a VOM.
I know the Grace pretty well (thanks Dromunds).
Anyone?
Dawgfish??
Come on, I know you know Steve!!!:redface:
Testing
Testing
Testing -
Kenneth Swauger wrote: »No, I'm afraid not, you might have to trace the continuity from head shell to connector with a VOM.
I have ZERO examples on hand here, in fact I do not own that ancient technology, although I must admit, it will not be long, and I WILL BE A PROUD OWNER!!
Its coming!:cheesygrin:
Thanks for reply Kenneth, much appreciated!!!Testing
Testing
Testing
