Sony 400-Disc Player
kberg
kberg Posts: 974
edited January 2004 in Electronics
All,
I'm considering buying the Sony DVP-CX985V 400 Disc player within the next 6 months.
Are there any other mega-disk players out there? Is the Sony a decent unit and can it be purchased anywhere for less than $400? Do these kinds of players tend to scratch DVD's due to their change-out capability?
Thanks in advance.
Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688
Post edited by kberg on
  • dorokusai
    dorokusai Posts: 25,576
    edited December 2003
    Kberg - If you are into the mega-changer, and the Sony in particuler, try and get into the ES class changer. It's build quality and DACS are much better than the lower end line of equipment in this category. The ES line also carries a 5 Year warranty.
    I have not heard of scratching issues. The only problems that I have heard about the Sony is, size....its quite large, but you probably already know that. I have also heard some cases of the disc library that you create, via PS/2 keyboard, being wiped out for no reason. This has been fixed per Sony, and I have not heard any recent cases of this happening.
    The Sony CDP-M333ES is often under $375, and has had good reveiws. The CDP-M555ES is often $475.
  • kberg
    kberg Posts: 974
    Excellent! Thanks, doro.
    Sub: SVS 20-39 PC+
  • madmax
    madmax Posts: 12,434
    You might want to ask around the forum to see if anyone has a similar used one they might want to sell...
    madmax
    Vinyl, the final frontier...
  • madmax
    madmax
  • ken brydson
    ken brydson Posts: 9,003
    I have both a CDP CX200 and a CDP CX400 and have been very happy with both. As Doro says, The ES line is better and carries a longer warranty but both of these "mainline" units have worked well and performed flawlessly for me, FWIW
    I just reread your post and saw that you were looking at DVD/CD combos. Mine are CD only......sorry.
  • bikezappa
    bikezappa Posts: 2,463
    Doro is correct. Try and get the ES model. I have the Sony cx8500 that holds 200 DVDs and two cx 255 CD players that hold 200 CD's each. I never heard of any scratching issues and have had none myself.
    They are big and I have broken off two optical connectors and damaged one RCA jack while moving these units around on the shelf. Just be carefull when pushing them around on the shelf.
    I'd buy new, not used. Too many moving parts.
    I wish Sony made a top notch 400 unit player.
    I'd get the M555es model.
    Shuffle mode is great fun. And track delete is power.
  • avelanchefan
    avelanchefan Posts: 2,401
    I have the model that Doro has shown above. Personally I love it. No problems, no skipping, no scratching. And you are able to use a standard CPU keyboard to insert individual CD info. I have had two blackouts, and the CD info is still in memory.
    Not to bad of a product that Sony has put out. This is refering to the CDP-CX455.
    Sean
    XboxLive--->avelanchefan
    PSN---->Floppa
    http://card.mygamercard.net/avelanchefan.png
  • John K.
    John K. Posts: 822
    KB, if you're looking for a combination CD/DVD megachanger under $400, the 985 is about it and should be fine(note the September Sound & Vision review). Here's a few sources.
  • rwrvpem
    rwrvpem Posts: 32
    edited January 2004
    I have 2 sony CDP CX200's that I use in my system. I have had both for about 5 or 6 years and they have been great for playing CDs. No scratching issues and the ability to have all my CD's available is great. The ES line would probably be better, but I can't really complain about the mainline players. When I sit down for a serious listening session, I still use my Denon 2900, but that isn't the norm. I will also agree that these things are big. Make sure you have enough room in your stereo rack.
    Good luck.
    Rick
  • todd1019
    todd1019 Posts: 8
    edited January 2004
    I know it is not the DVD player but I have the CDP-CX355 300 disc mega changer and I love it.
    __________________
    [HOME THEATRE]
    [TV] Sony KP-46WT510 HD1080i
    [AVR] Denon 3803
    [DVD] Sony DVP-NC685V
    [Front] POLK RTi-70
    POLK CSi30
    Kenwood to be replaced
    [Surround] Kenwood to be replaced
    [CD Player] Sony CDP-CX355
    [Game Console] XBOX
    Tivo
