Bass Mgt on a Yamaha..?
wrxmy02
wrxmy02 Posts: 92
I have the Yamaha RXV-V795.
This is what you can adjust and by how much..
2 channel stereo: Sub No adjustments can be made.
Over all surround mode: center+surrounds -20 to +10
Sub -20 to 0 [zero]
Dolby Digital LFE you can adjust from : -20 to 0 [zero]
DTS LFE you can adjust from : -10 to +10
Only DTS can you add more bass. I just have to ask:
Can your reciver add more bass other than DTS? This seems pretty limited.:confused:
Front: LSI7
Center: LSIC
Surrounds: LSI7
SVS PB2-ISD SUB [MONOLITH!]
ATI 1805 Amp
Post edited by wrxmy02 on
  • pjdami
    pjdami Posts: 1,894
    edited January 2004
    I wouldn't be too concerned about the LFE adjustments here. Keep the LFE for DTS and DD at 0 db. Put your Sub speaker setting at -3 to -5 db and adjust your sub gain on your sub amp using the Avia or Sound and Vision DVD. A lot of folks like to run about 3 db "hot" when you adjust the gain on your sub amp compared to the main speaker that you are adjusting your sub gain with. 3 db "hot" for movies and 0 db "hot" for music. I just leave mine on 3 db "hot" for both music and movies.
