Newbie ?
c_nitty
c_nitty Posts: 38
edited June 2013 in Vintage Speakers
Hello new here. I can get a complete set with the polk audio cs400,two fx500,and two rt100p for $300. I know they are very old but in good shape is this a good deal?
Post edited by c_nitty on
    F1nut Posts: 50,753
    edited June 2013
    Yes.
  • c_nitty
    c_nitty Posts: 38
    edited June 2013
    Yes.
    Thanks can anyone talk about the sound quality?
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    edited June 2013
    Sorry i can't help but welcome to the forum. Stick around. there are a lot of very knowledgeable Polkies around here, you can learn a lot.
  • c_nitty
    c_nitty Posts: 38
    edited June 2013
  • heartystatue
    heartystatue Posts: 329
    edited June 2013
    I only have experience with the cs400. I bought new and it sounds great. Just make sure you give it clean power. Welcome to CP.
    HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
    2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC.
  • c_nitty
    c_nitty Posts: 38
    edited June 2013
    Thanks I have a Yamaha rx a3010. Will be used 70% HT 30% music.
  • boston1450
    boston1450 Posts: 7,671
    edited June 2013
    C-nitty. If you happen to get the speakers. Enjoy them & welcome to Club Polk
  • c_nitty
    c_nitty Posts: 38
    edited June 2013
    Thanks for the info are the amps hard to replace or get fixed? I also hear I do not have to use the amp anything on how to hook them up thi ess way?
    DSkip wrote: »
    That is one of the best-voiced speaker lines Polk ever produced. They are great for any purpose and are well worth the $300. Be aware that the plate amps on the towers might need some additional work as the caps in them are known to go bad by this point.
