I Must be NUTS
soundfreak1
Dropped of the rta12c crossovers off at my techs house today, along with full complement of Clarity ESA. 250V CAPS and neutrek conectors, gold "slip on" conectors, new 14ga copper strand wire, and mills restors. I will be installing huricane nuts ( no spikes type) also gold 5 way binding posts. Have new gaskets for all drivers as well. Drivers already dynomated and tweets upgraded to 194's. Am expecting some serious results! Better be good for the expense LOL. Will follow up when finished.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Post edited by soundfreak1 on
You're NUTS that's all.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Yep must be. But is it the "hobby" that makes us NUTS or.......Yea thats it! I feal better already!Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Now that's some eye candy!!!
You have some serious stuff going on!!SRT Seismic System with dual PSW1200's
RT5000 x 2
RT2000p
CS400i
CS350-LS
LS F/X
PSW650
PSW1000 w/Dayton SPA1000
DSW MicroPro 4000
Adcom amps
Pioneer Elite SC-89
Pioneer PLX-1000 Turntable
PS4
XBOX One
MIT Interconnects
BJC -
Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
That's a lot of caps to make you go nuts...
LOVE IT!!
Can't wait to hear a review of the results.
And pics.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Picts will follow. It will be a week or so that will give me the time to do the mounting hardware and enlarge the hole for the neutrik conectors. Clean the inside and reseal the joints.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Yes, you are nuts! But in a good way. My prediction is you'll be very pleased once burn in is accomplished.
They are very good speakers in their original version, and at a whole other level with upgraded caps, resistors, H-nuts, dynamat.
May I make one other suggestion as long as you're removing the drivers: get a sheet of Black Hole and put 4" wide strips behind the MW's. It really helps to improve clarity during complex passages, especially at concert level volumes."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
I have heard of this being done but 4" wide and how long should they be? I visualize verticle strips? Some detail would be of help. Thanks evet though i seldom (if ever) raise the volune up due to room size. ThanksMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
soundfreak1 wrote: »I have heard of this being done but 4" wide and how long should they be? I visualize verticle strips? Some detail would be of help. Thanks evet though i seldom (if ever) raise the volune up due to room size. Thanks
It goes on the interior back wall, behind the MW's. Because they're side by side it's placed horizontally spanning the width of the cabinet. I found that it also helps at moderate volumes."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
drumminman wrote: »It goes on the interior back wall, behind the MW's. Because they're side by side it's placed horizontally spanning the width of the cabinet. I found that it also helps at moderate volumes.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Cant wait to hear these when complete, although i know it took nearly 300 hours fot the 5jr+'s to fully set in. In fact even after that i can still notice small changes in the sound. They keep getting better.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
soundfreak1 wrote: »Thanks while the cabs are open might as well do it as well. Will have to check some car audio shops in my area to see if i can buy in small piece to do the job. I can only assume it is expensive in rrg. package sizes.
$70 for a 24" x 27" sheet, enough to do several speakers. I did my 2.3TL's and RTA 12C's with one sheet.
I bought mine here: http://www.soniccraft.com/products/damping/blackhole5.htm"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
drumminman wrote: »$70 for a 24" x 27" sheet, enough to do several speakers. I did my 2.3TL's and RTA 12C's with one sheet.
Another 70. Bucks oh boy!!! LOL. Thanks for the info though. (got any leftover??? LOL)Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
I did my SRSs, 1Cs, and a pair of Allison 6s with one sheet of BH5.
One sheet goes a long way.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
