Ht receiver for RTI a3
murdan
Hi, I am looking to upgrade my Yamaha RX-V471. What would be the best choice, I will use the receiver for 30% movie and 70% music so I need it to be good for 2 channels music also.
I was looking at the Pioneer elite vsx-60 or Yamaha RX-A830. My main speakers are the RTI a3. I am looking to upgrade them for towers in a near futur.
Thanks.
Thanks.
Post edited by murdan on
Either one will be fine for the a3's The Yamaha has pre-outs for an amp if you decide to upgrade later.
I would definately consider one with preouts. Also don't forget Onkyo TX-NR series. Welcome to CP.HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC. -
+1 and then some on the advice to get an AVR with preouts so you can add a dedicated external amp.
I ran the RTiA3s as my fronts - and they REALLY sounded better with a good amp with power....really. :cheesygrin:
Check out the Marantz AV receivers You can go from around 700 to 2000 , and they have preouts. I have owned lots of Yammies, and like the Marantz sound much more for music and ht. Build quality is a bit better, and that is not to say Yamaha is bad... I have never had a problem with the 5 or so i have owned, but listen to the Marantz side by side with a comparable Yamaha and then choose.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Welcome to Club Polk!
Normally I'd say the Pioneer hands down. But since that Yamaha is part of the NEW Aventage series, I would say either one will do you. Yamaha has really upped their game with this series!
Marantz and Denon are also possibilities. I run a Denon with A3s up front in my basement system and it sounds fine!
