Sub Wiring
jagwoods
jagwoods Posts: 8
edited July 2001 in Car Audio & Electronics
I have two dual 4-ohm subs in separate boxes. Do I want to wire them in parallel or series to get the lowest impedence, and how would I do the wiring since they are in separate boxes. Thanks
Post edited by jagwoods on
  • Systems
    Systems Posts: 14,872
    edited July 2001
    I have no idea
    Testing
    Testing
    Testing
  • Systems
    edited July 2001
    For the lowest impedance you need to wire these in parallel. ( Connect the plus (+) terminal of each cabinet together and each negative (-) together.) Then to your amplifier or head unit. This will result in a nominal impedance of 2 ohms. Make sure your amplifier or headunit is capable of driving a 2 ohm load. (most if not all are).
    Testing
    Testing
    Testing
  • jagwoods
    jagwoods Posts: 8
    edited July 2001
    The amp is the MTX 81000D, I am sure it can handle a two ohm load. Thanks for all the help.
