SRT owners?
tntvt
tntvt Posts: 121
edited April 2004 in Speakers
How are the drivers in the SRT subs mounted? Are they on the front, sides or inside? Any photos? Thank you.:D
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited February 2004
  • dorokusai
    dorokusai Posts: 25,661
    I think they are front mounted with a power port on the bottom....but not 100% positive.
  • organ
    organ Posts: 4,969
    I believe they're inside the cabinet just like those Paradigm PDR subs.
    Maurice
    VR3 Posts: 29,762
    The SRT subwoofers are inside the enclosure, vented at the bottum by a power port if im not mistaken. The grills on the front are there just for looks...
  • Airplay355
    Airplay355 Posts: 4,298
    if they are like the rti100 subg they are pointed towards the back of the speaker and enclosed from the mid drivers. the port only vents the back of the driver. but then again i never opened up an srt
  • ken brydson
    ken brydson Posts: 9,107
    http://www.polkaudio.com/home/technology/srtpsub.php
    Doesn't state which direction though.....
    VR3 Posts: 29,762
    The 10 inch woofer is enclosed in the center of the subwoofer, firing down inside, not on the back, but like in an inner baffle (based on pics from har)
  • ken brydson
    Except there's 2, right?
    VR3 Posts: 29,762
    No, there is only 1 10 inch driver per
    There might be two, but i am about positive there is only 1
  • ken brydson
    Not according to the link I posted above
    VR3 Posts: 29,762
    It may have 2...
    Oh well, either way..they are mounted inside on baffles
    Yes it has 2...
    Might be one active, one passive...
  • ken brydson
    It may have 2...
    Yes it has 2...
    Come on Sid, admit it. You're guessing. The spec's state 35 active drivers in the system. No mention of any passives:rolleyes:
    VR3 Posts: 29,762
    I never said I was right...
    I said that it COULD be passive...
    It probally DOES have dual 10's...jeeeeeeeez...it IS ok..
    I have heard the SRT subwoofer(s)....and I would pay 1 grand for them things, easy...AWESOME subwoofers
  • dorokusai
    I do think that grille issue is correct, it is just for aesthetics.
    Har would know, but he doesn't participate with us anymore.
    VR3 Posts: 29,762
    Yeah the grill is there just for looks.... only thing behind that grill is wood ;)
  • Airplay355
    One SW1080 10" woofer each cabinet
    One SW1081 10" woofer each cabinet
    look at the model numbers......im thinking theres two in each cabinet. why would there be passive drivers in a ported inclosure?
    VR3 Posts: 29,762
    elifino -- Like I said, Maybe, Could, Heck...for all we know they could have 100 bose drivers floating around in there :rolleyes:
  • tntvt
    tntvt Posts: 121
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=8866&highlight=%2Asrt%2A
    I did go digging, and I found pictures from Har_navalta refinishing his SRT's. (see link above) I don't know what side is up in the picture. However I think it is safe to assume there are 2 - 10" drivers. And they do face to the front or to the rear.:)
    VR3 Posts: 29,762
    Yes yes there is, in that pic the sub is upside down... (notice port on the top (bottum) in that pic)
    I would guess that it fires to the port...my guess, but it is on a baffle....firing ;) I figured it would be a tad different lol
  • PolkWannabie
    The 10"ers (two per side) are mounted on a vertical center board firing into the cabinet which ports to the bottom.
  • vkf
    vkf Posts: 8
    Subs are mounted inside the cabinet, about halfway,facing forward 2 10 inch both active. You cannot see the drivers with the grills off, only wood cabinet .I had a SRT system for 3 years. Hope that helps
  • goingganzo
    goingganzo Posts: 2,793
    the subs are in a band pass setup to make the box smaller and to get more output for the driven power driveing.
  • Airplay355
    like a sunfire?
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello,
    The SRT bass unit has two internally mounted 10" woofers in a band pass enclosure with a downward operating Power Port. They are powered by a self-contained 300 Watt continuous bass amplifier.
    Regards, Ken
  • brody05
    brody05 Posts: 329
    edited April 2004
    To try to sort the confussion, I currently own and have pulled apart on many occassions the SRTs, for the record they have;
    2 x 10' subs each cabinet
    they both face forward and are mounted inside the cabinet about a third to half of the way back,
    there is a downward facing port the same as the RT and RTi active series of speakers but bigger of course
    they are 300 watts rms per channel and they go down to 16 hz,
    hope this clears things up, there is only a couple of others that know above what the correct answer was, and this should confirm it.
    Great site by the way, will enjoy many hours searching through it.
