Wall Mounting RT25's
Golferdude1977
I have a pair of RT25's that have been wall mounted using the keyhole slot. But I am wanting to angle them down. I bought a pair of speaker mounts but they only attach to two holes on the speaker. Are the 4 holes on the back of the speakers put there to use this type of bracket? And if so, will it work fine with just two being used? Thanks...
Golferdude1977
Golferdude1977
Post edited by Golferdude1977 on
I would try a clamp style mount, they are very adjustable. Here are some mounts from Crutchfield:
http://www.crutchfield.com/cgi-bin/S-GiX89vsttSC/ProdGroup.asp?c=9&s=0&g=15830&cc=01&search=
The picture is the one I use on my RTi38's. This is a little stronger than you probably need.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I used a long screw into a stud for my 28's and angled it upwards. Once the 28 is mounted, the speaker angles downwards.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
