LSiM Speaker Wire Terminations
[Deleted User]
[Deleted User] Posts: 1,225
edited June 2013 in Speakers
Soliciting suggestions for some decent speaker wire terminations to connect up to the new LSiM's. Price is not too much of a concern but I don't want to break the bank either. Thanks. :cool:
  • zingo
    zingo Posts: 11,258
    edited June 2013
    I like the silver spades from Luminous Audio; easy to solder and a very simple silver over copper.
    http://luminousaudio.com/terminals/spade.html
    F1nut Posts: 51,673
    edited June 2013
    Tony, if I'm understanding you correctly you have the speaker cable and are looking for banana plugs or spades. I'd suggest looking at the MIT ICONN system, which consists of a threaded base piece that you solder the wire into and then screw either banana plugs or spades onto it.
  • [Deleted User]
    edited June 2013
    ^^ Yes that is correct. Banana Plugs most likely, can't use the dual bananas on the LSiM because of the spacing. I'll check out the MIT's. Furotech has an angled set of bananas (4) for about $90 that look tempting. :cool:
