HDTV Antenna
jdelan
Is there a Specific HDTV Antenna or will any ole Rabbit Ears work to pick up the signal over the air?
Post edited by jdelan on
I think they are having a seprate antenna. I saw one of those in ebay!
jdelan:
You are so close to the DC transmitters that if you've got an old set of rabbit ears laying around it would be worth a try.
As far as inside antennas are concerned I've heard a lot of good things about the ANTIFERENCE Silver Sensor Antenna.
I'm also located in the DC metro area, in Fairfax Station. I'm further out and in a low spot so I use a Channel Master #4248 DIAMOND QUANTUM with a Winegard AP4800 preamplifier.
I hope this helps.
Larry
