low volume in zone 2
Easy Runnin
Easy Runnin Posts: 501
edited September 2013 in Basic Hookup/Wiring Questions
In my family room I have an Interga DTR-30.3 with a powered zone two, a Technics SL-D3 with an empire 3001T cartridge, an NAD 513 CD player, and an NAD 304 integrated amp. The Interga does not have a phono input and the amp section on the 304 isn’t working right so I’m using the 304 as a preamp for the turntable. Due to location limitations the turntable, CD player and amp are in one location and the Integra is in another. The turntable and CD player are hooked up to the 304, and then I run a 20-foot RCA cable from the NAD to the Integra. From the Interga I run about 30 feet of speaker wire to a Sonance SS4 speaker selector. From the SS4 I have 2 runs of approximately 60 feet each; one runs is for a pair of speakers in the living room the other runs is for a pair of speakers in the basement. I usually only listen to one pair of speakers off the SS4. All speaker wire is 14 ga. The Integra is also hard wired to the Internet.
If I listen to Pandora or FM through the Integra with the volume set at the same level in both zones, the actual volume is slightly less in zone 2.
When listening to the CD player at the same levels, the actual volume in zone 1 is greater than the actual volume when listening to Pandora or FM in zone 1. At the same time the actual volume in zone 2 is noticeable lower than the actual volume when listening to Pandora or FM in zone 2.
When listening to the turntable at the same levels, the actual volume in zone 1 is slightly less than the actual volume when listening to Pandora or FM in zone 1. At the same time the actual volume in zone 2 is noticeable lower than the actual volume when listening to the CD player in zone 2.
Can anyone explain why this happens and how I can compensate for the extremely low volume in Zone 2 when listening to the turntable?
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited June 2013
    I feel your pain and most here would say that's a convaluted system ,but for you it works kind of. I also run a zone 2 off my Yamaha RX-V-665 and it's about a 30' run done w/ cat-5 of all wires and I get no degregation or loss at all. My computer is even more wacky ,out of the headphone jack into a mini plug y splitter into 2 RCA cables back into the Yammy again 30'. It also works only once did I p/u a hum and that was due to the way my rack ac cords were run. Why the loss on just the turn table I don't know my tt is just for my 2-chll and not connected to the avr at all.
  • Easy Runnin
    Just in case anyone cares I think I finally figured it out. I did a hard reset on my receiver. After the reset the sound in zone 2 was very similar to the sound in zone 1. After running audyssey the sound in zone 1 was noticeably better than the sound in zone 2. The difference was even more noticeable after tweaking dynamic EQ and dynamic volume.
