Monitor 60 replacement - smaller room
whitemtntn
whitemtntn Posts: 26
edited June 2013 in Speakers
We moved. The entertainment room is smaller...
I have Monitor 60's as fronts, CS2 as center and Monitor 30's for rear surrounds.
Unfortunately it looks like I'll need to sell the Monitors 60's-- too big for room.
I'm thinking about keeping the CS2 which I really like, using the Monitor 30s as fronts and getting OWM3's for rear surrounds. Any thoughts on whether this will work nicely or any other suggestions?
Thanks very much.
Post edited by whitemtntn on
    tonyb Posts: 33,065
    edited June 2013
    I don't see why not. You may have to get a subwoofer to fill in the lower frequencies but for a small room, sure...fly with it.
    Curious as to if you plan on putting the 30's on stands or on a shelf. If on stands, are you really gaining any room over the 60's ?
  • whitemtntn
    edited June 2013
    Sorry didnt mention-- I do have a subwoofer.
    Good question. I think I'll be able to put the fronts on a shelf, or possibly mount to wall.
    I guess my main questions, I know I'll be losing a fair amount of midrange from the 60s-- are the 30s decent as fronts, will they match up well with the CS2.. should I just scrap the whole setup and go in a different direction..
  • rpf65
    rpf65 Posts: 2,127
    edited June 2013
    If you have room for a second pair of 30's for rear duty, why not another set? Price is about the same.
